[APP][Pro][DEPRECATED] We Connect / myAudi / MyŠKODA / My SEAT / My Cupra
App is not starting charging of my Audi? Trued ro make a flow and charger is in manuell.
Hey @Kjell-Are_Torkildsen
Saw your report.
Your car is added incorrect
Remove it from Homey and re-add it as a Etron
(Second option)
Trued now, but do t get any info now
@Kjell-Are_Torkildsen I see, there’s a small issue will make a fix for that soon :slight_smile:
New app update (LIVE: 1.12.7)
Changelog:
  • FIX: locked/unlocked for New cars (ID/Etron/Cupra/Enyaq)
Changelog:
Changelog:
Changelog:
Changelog:
More - apps - AppName - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
@Kjell-Are_Torkildsen should be fixed in version 1.12.7 :smiley:
@martijnpoppen the cards “Car came/left home” for Skoda electric is not available even tho it says on the forum they should be.
Hey @Henrik_Petersen
Where did you see that information? :slight_smile:
It’s not available for the Skoda Enyaq. As the enyaq doesn’t report it’s location
EDIT: if you mean you saw it on the APP page. then yes: it does show there, but the Skoda Electric is a combination driver for Legacy and New API. Where the Enyaq uses the new API.
Once the app starts it will check per device (car) what the possibilities are and will add or remove based on that mapping.
The mapping you can find here: com.vag.core/capability_map.js at master · martijnpoppen/com.vag.core · GitHub (SkodaE)
I can’t start or stop anything from app
@Kjell-Are_Torkildsen looks like theres something wrong with the API. I would suggest a app restart and see if that resolves things
Hi Martijn, just some observations on eGOLF integrations :
  • Remaining climate time got updated last time a month ago for me :wink:
  • Is Climations on - 3 months ago
    (car is in daily use, with daily departure times set)
  • when I press Start Window Heating it stays on forever (but seems to be working) - would it be possible to make it “Toggle switch”, eg. turning off after 10min or so (or even sooner)
And yes, I believe I haven’t found any IoBroker value, which would report climatisation state but there are many values…
I sent you also diag. report, eg. 1.5 hour ago climations was on.
No big deal but I was thinking I will let you know so you can have a look. The original app reports state correctly.
Thank you :wink:
Will have a look @Sharkys
FYI to all - today my Homey integration stops updating any data, all seems to be fine, no errors in Martijn’s VW integrations, nothing…no change on restart.
So I started ioBroker integration and it gave me login error???
I went to myvolkswagen.net - Choose your market / language, logged in, got new message on consent on Terms of use…accepted (again ?! I would bet I did it already in the past) - and… no change.
So I went to the We Connect app itself, logged off, logged in - again got Request to agree Terms of use consent … and… it’s working now in both ioBroker and VW We-Connect. No idea why it didn’t work while using myvolkswagen.net - Choose your market / language (I did it twice) but luckily it works now again even without any app restart. @martijnpoppen I sent you logs, not sure if you will see anything there , would be great to get some kind of error in case of login error. Eg. some kind of log for users would be great (in settings, disabled by default) Eg. like it’s use in case of Google Nest integration from Martin - Homey Community Store (just in case you don’t know what I mean).
Hey @Sharkys
I checked the log and saw the error with the url.
I can probably fix that it will show as an error.
Last month the same happend for somebody with a Skoda. Seems like this problem is spreading now :confused:
Not sure if the IObroker integration will update. But might be the case.
I’ll keep an eye on the GitHub
Thanks Martijn - it reports problem with URL but after you re-accept the Terms of use, it’s okay again. I believe there is nothing to be updated as such, just reporting back the login error and the cause above might be one of them (also bad user name, password etc). But currently your integration on Homey side reports nothing and looks like everything is working fine but it isn’t.
Yeah correct i’ll make a update that shows the error.
What i meant with checking the IObroker integration: you can accept terms and conditions trough an API. So that might be a possible fix for the future
New app update (LIVE: 1.12.8)
Changelog:
  • NEW: add terms and conditions message
Changelog:
Changelog:
Changelog:
Changelog:
Hi Martijn,
seems some values are negative now…
I sent diag info
Hi @martijnpoppen the values for maintenance are inverted with the latest release. -236 days. And -21000km. All maintenance alarms went off :rotating_light:.
Could you please change them back and add “till” (of tot) maintenance?
-236 days feels like I’m 236 days late (with maintenance that is :sweat_smile:)
Thanks again!!
