[APP][Pro][DEPRECATED] We Connect / myAudi / MyŠKODA / My SEAT / My Cupra
I’ll be patient then :grimacing: Tried starting charging but that did not work, maybe after the next update
Yes sorry!
The memory leak fix feels like a couple of steps back. But we’re getting there! :stuck_out_tongue:
no need to apologize! :+1:
New app update (test: 0.7.6): (auto update only)
Changelog:
  • FIX: refresh tokens
New app update (test: 0.7.8): (auto update only)
Changelog:
  • FIX: temp rounding + buttons for flash and honk
So after a drive today my data updated perfectly and the memory leak seems gone. So everything should be working again. Looking forward to the feedback.
But as I didn’t hear anything yet I think it’s good right? :stuck_out_tongue:
CC: @SvenRhein can you verify that the leak is gone?
I will check tomorrow
Me too
@martijnpoppen I was just able to wake up car with START/STOP Climatisation, which is I believe good sign. However even when I set temp to 23C, after 3 minutes it reverted again back to 22.9C - I believe there is somewhere rounding error still. Btw Force refresh - again coming back to this, this is Toggle button still ? When I press it, it stays, like the others buttons, enabled for ever…
Hi
Got my car back in the app again. I can lock/unlock but still can’t start climatcontrol.
I have a VW Tiguan 2.0 CLOPF4M 140TSI.
It would be so sweet to build a flow that’s start the heater!
Thanks for your effort!
//Bosse
Nice!
Will check. Can you send a report for that?
No Both States are triggering the force refresh…but the Homey UI is not showing it correctly :frowning:
But when you click it again it Will Just forcerefresh again
@Bo_Bjorkman can you send a report?
How do I do that?
In the mobile Homey app:
More - Apps - VAG connect - settings wheel right top - send diagnostic report
Ok
d06a83ca-befa-4821-8ac9-406c70dcb217
@martijnpoppen here you can see the memory consumption
looks fine :slight_smile:
@SvenRhein yes that looks good! :smiley:
@Bo_Bjorkman do you have the climate option in the VW connect app?
The API returns an error for your car
error":{"errorCode":"climatisation.auth.forbidden","description":"The service: rclima_v1 for VIN: ABCDEF could not be found."}}
You can also try climate v2 or v3
Sorry accidentally hit restart - so I have simulated the same and hopefully you will see it.
dd288253-03c3-4466-9e7a-5d7f1de003d8
Apologies for my ignorance - so is the best way to turn it on and right after off? :slight_smile: The same for Start/Stop buttons or in case of climatisation turning it on and right after off, will actualy turn it off right away. Or those Start/Stop buttons get refreshed according to the real state? A pity that Homey UI is faulty for that :frowning:
Also is the “Temperature has changed” trigger working? I just created test flow and while temp.got updated, the flow (just one trigger) hasn’t been executed.
Any test version available? I have a VW e-up 2015 model
