[APP][Pro][DEPRECATED] We Connect / myAudi / MyŠKODA / My SEAT / My Cupra
great work dude :index_pointing_at_the_viewer: :facepunch:
great job @martijnpoppen
New app update (test: 0.7.5): (auto update only)
Changelog:
  • FIX: data update
Hope it works again :smiley:
Seems like it, and I think climate also works now, at least climate v2 seemed to start and stop :ok_hand: (Didn’t try the other options yet; Don’t want to “overload” the connection to the car with too much tries)
Will try some more later
I got some really nice and fresh data in the app! Bravo!
I can’t even log in any more. What am I doing wrong? Vw Tiguan 2020 fuel. When I try to add my car by login in I just being redirected back to login.
@Bo_Bjorkman then no car can be found. So that might occur when you select the wrong model or when your account is blocked by VW
I would swear that I was able to start and stop climate this afternoon, but at the moment nothing happens when I use climate v2 (like this afternoon). Other options also don’t work
Hi
Will they unblock me after some time?
Best regards,
Bo Björkman
@zakraket can you send a report
@Bo_Bjorkman yes
Had the same today. Takes some time.
done.
I saw the car outside status led turn on and off because of actions in the homey app (led status indicating climate on/off), I checked that state also with the audi app. I’m fairly sure it was not caused by the audi app
I’m not sure what I did because I did not expect it to work, but I think I used climate v2. Did not work earlier this evening though
@zakraket thanks
See some expired tokens. Will look into that.
Alright found it.
Before all the calls were happening in the background. Due to the memory leak fix they are not anymore (which is good)
But I’ll have to create a expired token check.
Will add that tomorrow :slight_smile:
I don’t wanna be pain in the… unfortunately for me the background updates still doesn’t work even on latest version … it got updated after I have restarted VAG App after 6:15, but prior to this, nothing unfortunately.
Again comparison of IoBroker MQTT integration with update interval of 11min and VAG App with update interval of 5min - both vwv2 protocol…
Diag info : b6703280-1a07-4a09-8f75-8ba886777f22
@Sharkys unfortunately nothing to see in the logs… :confused:
But let’s see if the token refresh also Fixes it for you
I’m still on 0.7.5 (did you update from 0.7.5 yet?) and since 15:00 (got 0.7.5 at 15:06) yesterday my car doesn’t update (outside temp stuck on 10.4)
Just restarted the app which updated the data (the outside temp is the only value changing of course), I also was able to start and stop climate (v2)
@zakraket yes think Will be related to above :point_up:
No not yet :slight_smile:
