If you’re like me and using Danfoss Ally products for managing the temperature in your home, you probably missed decent options to integrate these products in your automation flows. As far as I know the only option was to have them run via the Tuya app.
This app does what the Danfoss Ally app can do. It requires setting up a developer account at Danfoss (explained below) and uses their API to read and control the devices.
A big thanks goes to the developer(s) that made the HomeAssistant app. They did al the heavy lifting. All I did was instruct my AI Agent (Claude) to port the code. Honestly, I did some testing of course but that’s about it. You can buy MTrab a coffee via this link: https://www.buymeacoffee.com/mtrab.
I’m limited to the devices below, these are all I have. I’m willing to help out to get more device types connected but since I don’t own them that might be a little bit harder to accomplish. Just so you know.
Danfoss Icon2 Main Controller (no capabilities)
Danfoss Icon2 Room Thermostat with IR floor sensor
Danfoss Icon2 Room Sensor
Danfoss Ally Radiator Thermostat
Danfoss Ally Room Sensor
Danfoss Ally Gateway (no capabilities)
Danfoss Ally Zigbee module
Flow charts
All default thermostat and sensor flow charts are available to use. Read and react on temperature or humidity changes and set temperatures in your rooms.
Installation
After installing the app you must register and create an application at https://developer.danfoss.com. It’s as easy as signing up and creating the app via your user menu. Choose a name and make sure to select Danfoss API on the right side. After saving click on your app name where you’ll find the app id and secret codes.
Make sure both your Danfoss Ally app and the developer account use the same emailaddress!
In your Homey visit the apps page, open Danfoss Ally and add both codes to their respective fields in the settings. As soon as you’ve done that, you can add the devices, add them to the correct rooms and start automate the temperature settings or use temperature/humidity values in other flows.
I’ve created a little video how-to on what steps to take:
Roadmap
Right now there are no plans for new features, but feel free to request things you’re missing.
Changelog
Homey Appstore
Source code
I’ve open-source the source code of this app. It can be found in the Github repository below. Feel free to contribute.
