Ok thanks for the confirmation.
My issue was solved after I succeeded in having the homey cloud connection restored.
(in my network setup all the devices are forced to use my local dns and for one reason or another this resulted only in the past days in the homey loosing cloud connection, no other devices had a similar issue)
I don’t know if the Gen4 devices cause problems with the HP19. And if the Gen4s do cause problems, it will certainly make a difference whether they are connected via Wifi or Zigbee.
Btw, if you want to use Zigbee devices with the HP19, there are a few points to consider anyway, e.g. first add the router and then the end devices. Information on this can be found in the support area.
As far as I understand, Gen4 devices are only supported through wifi i the Shelly App for Homey at this time?
I assume Drenso (app maintainers) are working on implementing zigbee support. Eagerly awaiting it as I have installed some Gen4 devices to operate as zigbee repeaters for some new smoke detectors.
I think you’re right because no Gen4 Zigbee device shows up when you add devices to the Homey via the Homey Shelly app. Only Z-Wave, Wifi and Bluetooth devices are shown.
But if Zigbee is supported, they will extend the Zigbee network, @Maikel_Van_de_Wouw.
Hello everyone,
I’ve integrated a Pro RGBWW via homey. I’ve connected an RGBW LED strip, not an RGB CCT. The RGB control works perfectly, but warm white can’t be programmed via advanced flows.
Homey has a selection menu above the button for switching between RGB and warm white. When RGB is switched on, the strip is also displayed as “ON.” When warm white is switched on, it is permanently displayed as “OFF.”
I can manually switch warm white on, but in the advanced flows, there’s only one option for ON or OFF, and this only controls RGB. Warm white can’t be controlled in the flows.
I have a Shelly EM with 2 clamps, where clamp 1 is for Airco and clamp 2 is for solarpanels.
The integration in Homey works perfect for both clamps/channels. As shown in the screenshot.
But when I remove device “2 - Zonnepanelen” the data (-2.15 kW) is transferred to “1 - Airco”. So the last device is also showing kW from the Solarpanels.
How can I configure the Shelly device, or Homey Shelly app, so that “1 - Airco” is showing the correct values?
I have installed a Shelly Wave Pro 3. I had no trouble adding it to my devices, but I’m not receiving any data regarding power consumption. However, the main reason I added it was precisely to monitor the consumption of an electrical circuit.
Hi, my shelly bluetooth button stopped working. After a power outage, the flow with my shelly button stopped working. I tried removing the device and adding it again. All of this works, but if I create any flow - it is unresponsive. Homey Pro 2023 finds the shelly button, but the flows don’t work..can anyone advise?
