Also problems here after update to 3.16.1:
I was already experiencing problems with memory leak, had to restart the app every 1-2 weeks
But now the memory use is rapidly increasing en had to restart the app every 15 min
Last attempt before doing a complete code rollback to 3.16.0. Please try version 3.16.4 which is now in the test channel.
Checked the Shellyâs and they are up to date. Homey was updated this morning to Version 8.1.2
I try the new update 3.16.4 but same problem as before
Same problem
3.16.4 - the same problem. All devices unreachable and app time out for restart
intersting: using now 3.16.4 and shelly 1 does not respond on http. I disabled the app, restarted the shelly and then could access the http gui. so I reenabled the app and then they are again not accessible by http. ping still works
Still not possible to reconnect my Shelly 2.5 Devices. Double checked for Firmware Update at the Shelly GUI. They are not conected to the cloud.
I have reverted the code refactoring in version 3.16.5. There are only small changes compared to version 3.16.0. Please install and let me know if that fixes the issue.
@Homeuse his/hers comment above is interesting though. If someone affected by this issue could restart their Shellies from the Web UI and then try the production version of my app (3.16.1) Iâd like to know the result as well.
Everything seems to be back to normal. On 3.16.5.
Seemst to work for med now. ![]()
Works on 3.16.5đ
confirmed, 3.16.5 works again and http gui accessible again
Ok thanx, Iâll push this to live. I still need help in testing a new version that does include the code refactoring but does not crash. This refactoring was done with a reason. So I still need to make it work.
Still not able to re add devices. Everything is working fine
As mentioned, read and follow the steps from the first post. You need tu update the firmware and it will only show the new version when you first connect the devices to the cloud. This is unrelated to the issue of today.
Version 5 seems stable. Thanks.
Got the update seems ok
Thanx for your reply but i still got issues. Maybe you can hep me. If i click the button to enable the cloud there is a message âCloud canât be enabled when a gateway is not provided!â. On other devices it works. Any suggestions how to fix it?
Never heard of that. If you post a screenshot here I can ask Allterco Robotics (the company behind Shelly).
