@frient , after the last app-update, WHEN “Energy changed (kWh)” card is removed for the EMIZB-132 . Is it possible that you can add it again?
Tried to remedy with the WHEN “energy consumed becomes larger then xxxkWh” card, but that just trigger once, and not more that one time.
I pushed the update to the app store (2.5.1).
It’s in the review, but you can already install it via this link:
@frient , installed test release, It does what it is supposed to. Thank you!
Sorry if this is already mentioned… Tried to search.
After the update last week both EMI Norwegian HAN keeps bugging.
Tried v2.5.1, but no joy.
Sometimes it work, but mostly not.
Any ideas?
What home electricity meter do you use the device with?
Kamstrup
I don’t have the model a.t.m but its a three-phase meter
I’ve seen on other forums that others have the same issue after the last update. Don’t know their meter
That’s strange - we’re testing this device on Kamstrup meters.
Could you share the link to the other forum you mentioned?
Have you tried removing the device from your Homey, resetting it, and adding again?
It was a FB forum. For some reason I can’t find it… I’ll send if I come over it again.
I’ve rebooted Homey, rebooted the app, installed the v2.5.1, disconnected the HAN and connected it again.
I haven’t tried to reseting the device.
I can try reseting the devices when I come home later today. But I should mention: I have 2 HAN. One in my home, and one in the garage. both connected to Homey. Same issue on both.
Up til this weekend it worked sporadically, but as of this weekend, none of them has updated the usage. just keep getting the error message.
I deleted the units and reinstalled them. Seems to be working now. Thanks ![]()
Hello, ive got an EMI Norwegian HAN.
Lately ive gotten some problems, everytime the hpmey reboots ( for updates etc.) The energy meter stops. To fix it i restart frient app in homey and it starts again.
Is it a possible fix to not make it stop?
What do you mean by “the meter stops”?
Can you share some screenshots?
Please remove the device from your Homey, factory reset it (hold down the button until you see the LED flash multiple times in a row), then add again.
Should be fixed in version 2.5.3:
Just want to mention, it’s working now ![]()
Hi Ted,
Has there also been changes to the P1 sensor?
And if so, do I have to remove and re-add the device?
Thanks!
This works so nice that i almost hurts. Beautiful work! Love the multiple users access.
Would be nice to eventually see " ‘Entry validation’ ‘Method’ is entered" in Heimdall, which currently only works locally. Not a deal breaker whatsoever, just a nice touch.
Is it possible to remove the step “Arm/Disarm” after holder up the RFID tag?
So instead of holder RFID then type “Arm”, the system would already know to Arm/Disarm the system after holding up the RFID.
