@Arie_J_Godschalk
I saved a script once, this shows all timers/stopwatches/transitions used in flows.
From the returned data I think it shows all timers etc. I created and occur in a flowcard.
Might be of any use, Arie!
To do it this way, i would need to include the very heavy-on-memory AthomAPI.
And there is no need, i already have everything i need to get it from the sdk itself, so no npm/athom-api needed.
With your device app I would perhaps put all stopwatches and timers in one device. Thats now possible @DirkG . Instead of all separate tiles. In the settings menu is also nice opportunity.
Or even better a drop down or is that difficult to make?
Just so you know, over 700 apps are already running on SDKv3 , probably more then half of the apps currently already active on your Homey.
There are no really SDKv2 Homeys, unless you haven’t updated your Homey to and past Homey firmware v5.0.0.
Dude, I didn’t manually create the “unsupported for Homey 2023” a.k.a. pretty much all SDKv2 without a reason I know full and well that losing SDKv2 apps is bad.
And it wasn’t what my responds was about at all, he asked about SDKv2 Homeys and thus I responded.
Hi @Arie_J_Godschalk
I made a post (231) here a few days before you took over this app. I have now installed the test ver 1.2.3 and when the app was up and running again I had same issue again with the when card transition reaced a step. It doesn’t trigger the flow. The transition, timers and stopwatches are running like they should. I also notice that when I pressed resume manually on transition it start counting for 3-4 sec and then stop and went back to previous time. It did not behave like this before.
After resetting the transition, adjusting the time and resume transition from flow, the when card works again. Seems like an issue when app updates and Homey restart (I have not tested restart of Homey this time) that the when card doesn’t trigger as it should.
Hope this is an easy fix.
is the app aware of running delays or timers? I’d like to only set another yes/no variable to “No” if no timer or delay is running?
Let me be more precise. I know there’s the AND card for particular running Timers. I was wondering if there’s a way to state “NO Timer” is running for all existing Timers. Makes sense?
Thanks for your report.
I cannot simulate the issue, tho.
Whenever i restart the App or Homey, everything works just fine, when i try to start a transition.
I am changing some stuff so i can better debug these/this issue, to get to know the sourcecode and the more i play, the faster the possibility of finding bugs.
