It works. Thank you
Shold be fixed in new version 2.0.1. Thanks for reporting.
hey Ronny ![]()
YOU are the man !
Thank you so much !
Works great so far
@RonnyW thank you sooo much!!! Without you and your app I would not stick to Blink. But now I can keep my system.
Big respect to your work and to your engagement for the community. Hope I can do anything for you in future. By the way, works perfectly. Thanks!!!
Thanks so much!!Your update resolve the problem😁
2.0.1 invalid login… after automatic update.
Need to install it again… and its ok
Ronny, it’s working here. Thank you so much. Andrew
You have to ‘repair’ the account device - just login again in repair view to authenticate with the new API.
Thank you very much for the direct email. In version 2.0.0, it didn’t work for me (error 426), and I had the same issue. I then installed the new test version 2.0.1, and I was able to log in. A token was triggered via SMS, the token screen appeared in the Homey Blink app, I entered the token, and everything worked. (I should also mention that I restarted the Blink app in Homey.) Perfect, now it’s just like it used to be. Great job, and thank you for your effort and the time you invested. ![]()
The token refresh (after 24h) fails with current version. A fix is in work…
New test version 2.0.2
- Fixed token refresh
Ronny
I had it working on the version you released on here but the homey has just updated to 2.02 and I can’t log in again. Error426. Any ideas??
I’ve just checked and the app on the homey says 1.2.2 - I thought it auto updated?!
Just to let you know… I followed your instructions with the test version and everything is now working correctly. Thanks for the updated version.
Version 2.0.2 is live now ![]()
It seems the last update (fix for token refresh) broke the auth with user/password. A fix will be provided this afternoon…
Ronny
the app now says the right version and it is working. Thank you very much.
Andrew
It works!! You are a boss @RonnyW
Thanks a lot
