[APP][Pro] Better Lights for Homey
:light_bulb:Update v2.0.5
New Live version!
Improvement
:glowing_star: Overall App Enhancements: Experience an improved Better Lights App with various enhancements aimed at enhancing usability and performance across the board.
With Better Lights, managing your lighting setup becomes a breeze! :light_bulb: Easily combine three actions into a single flow card, simplifying brightness adjustments, color changes, and toggling on/off. :artist_palette: Experience streamlined control and elevate your smart lighting automation with ease! :dizzy:
Download the new version in the Homey App Store!
Changelog
Encountering any issues? Help us help you by sending a detailed report via the mobile Homey app.
More - apps - Better Lights - settings wheel top right - send diagnostic report (include your email and issues in the input field for better assistance)
Contributions
If you appreciate this app, fuel future development with a PayPal contribution, buy a round with iDeal or Bunq.me, or become a true supporter on Patreon. Your support keeps the magic alive! :sparkles::rocket:
Why does this need permission to “Manage entire Homey?”. Generally not keen on installing apps that require this, unless there is a very good reason, especially as this app should only be changing light settings?
This is necessary otherwise the app cannot control your devices (lights).
Why?
Hello all,
I appear to have ran into a bug (or I might be doing something wrong, which I am certainly not excluding either)
I am trying to use Better Lights in combination with 4 Ikea Tradfri lights and a Tradfri (soon Vallhorn probably) motion sensor.
The first and last flow turn on the lights, but do just that. They don’t change any color or brightness level. They both target single lights.
The middle flow targets an entire zone, and this one does work.
I want the flow to work as the first one. So set the three spots to a certain color and the led strip to another one.
Am I maybe doing something wrong, or have a encoutered a bug?
Kind regards,
Mark
Hi @Mark_Jansen can you send me a report please?
Done. Thanks for the quick reply.
Hey, this is a very helpful great app, there’s only one feature I’m missing: that’s duration for THEN card settings, i.e. like Dim to 100% over 2 seconds. It’s not available, no – or did I miss something.
Thanks
@LRvdLinden just found your app while looking for an easy way to solve this. I was wondering if it might be possible to extend/duplicate some of the cards affecting multiple lights to read something like this:
  • Dim [[light_state]] lights for [[zone]] to [[%]]
  • Set [[light_state]] lights to color [[color]] for [[zone]]
  • etc
With light state being either all (default), turned on or turned off.
Because I think only wanting to influence currently turned on lights in a room for example is a pretty common use case.
Is there already a solution for this question?
Or is it possible to also switch on the lights for a certain sec?
I have IKEA tradfri and i’m trying to set a zone to warm white for a zone. I know its 2700K but i don’t know what to use in your app? I asked chatgpt what hex color warm white was and i got #FFD966, it was green’ish.
Where can i find explanations for Temperature, Hex color, color and saturation
+1 Great app
I miss zones at all choises. I would love to be able to change dim level and temperature to one or more zones.
If this happens i will ditch my trådfri hub.
I have the same ‘problem’. Trying to build a flow, to cycle thru different scenes (like with wall switches in het HUE app is possible). But the switch goes very un-smooth. Any soluitons by anyone?
I had a question about the betterlights app.
I see that you have a flow that you can dim all lights in a zone. But I still miss the possibility within homey to switch all lights on/off in a zone with a flow. Is there a possibility that you create that card in the betterlights app??
I would like to hear!!
So this:
but then for a specific zone and then for lights.
Better Lights is an amazing app, but i notice that if i use the card Set a temperatuur for Light a at 30% that if the light was on before with another (higher) percentage, that when the light goes on first it goes to the previous percentage before going to the 30% . I am doing something wrong or can i change a setting ? I Would love to hear.
It’s a fundamental issue with Homey and how the commands are configured
For instance, if you set a colour the light will turn on as the previous colour first.
You need to use Zone Memory to get around this
Why is this app no longer available in the store? Is there an alternative?
