New app update (
TEST: 1.9.5):
Changelog:
NEW:
1: None
FIXES:
1: FIX: persist backoff and trust tokens across restarts, stop futile sign-ins
2: FIX: fewer retries when Apple has blocked an account + explain how to unblock it
3: FIX: distance in km and miles no longer refreshes while the device sits still
4: FIX: repeated Apple login emails - a rejected session no longer earns a new sign-in every refresh
5: FIX: no longer refuses an Apple ID over a terms notice iCloud itself ignores
6: FIX: a clear message when a device is offline instead of an iCloud error code
7: FIX: diagnostic reports no longer get flooded out by device logging
8: FIX: Apple login emails - the iCloud session is now kept alive, so a long polling interval no longer costs a sign-in notice at every refresh
9: FIX: battery level no longer stays frozen when Apple leaves it out of a refresh
10: FIX: diagnostic reports now hold far more history, by logging only the values that actually changed
If you find any issues, send a diagnostic report
Note: Before sending a report make sure to reproduce the issue so the issue will be visible in the report
Via Homey Mobile app:
More - apps - Apple Findmy - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
Via Homey Webapp:
Settings wheel bottom left - Select Apple Findmy - Click on send diagnostic report
You can install this version by clicking the link above and press install (do not remove the app, only press install)
Don’t want to be part of a test version? Install the live version → Find My | Homey
So new investigations:
Apple drops the iCloud session when the app leaves it quiet for a while. The next refresh has to re-establish it, and that’s what Apple reports to you as a login. So the emails depended on your polling interval: short intervals kept the session alive and stayed quiet, long intervals found it dead at every refresh and mailed you each time. @Drako74’s flow moves his interval between 2 and 15 minutes when he leaves home, and the emails started and stopped right along with it — that’s what gave it away.
1.9.5 keeps the session alive on its own timer, so your interval no longer decides this. Nothing to change on your side.
This does not add any requests to your devices and won’t affect their battery. Your interval still controls that completely, the new timer only talks to your iCloud account, never to your devices
If you still get login emails on 1.9.5, please send a diagnostic report, that would mean there’s a second cause and I’d want to see it.
He martijn
But i had 15 min intervals during the night … no mails
So the 15 min is not the cause
@Dennis_H74 but the cause is the interval, so i separated that. so device update and account keep-alive are 2 separate things now
@martijnpoppen
Unfortunately i had 5 mails after latest update
Nothing after 3.03 so far and not an even pattern in times
@Dennis_H74 thx I’ll check again. But I think there’s not much anymore to polish in this last version
I’ll push it live though, then we can see if it works for everybody.
New app update (
LIVE: 1.9.5):
Changelog:
NEW:
1: None
FIXES:
Via Homey Webapp:
New app update (
LIVE: 1.9.7):
Changelog:
NEW:
1: None
FIXES:
1: FIX: the session keep-alive no longer renews a dropped session, which could send more Apple login emails than it saved
Via Homey Webapp:
Hello @martijnpoppen
Over the past week, I have encountered significant trouble with the app. Four units are listed there, yet only one updates as expected. A few days ago, the unit functioning today failed while the other three worked; I am unsure what is happening.
Sending a diagnostic
84652205-4f36-4285-b093-0429cbd8456b
@Daniel_Fille please explain your issue. “Units not updating” doesn’t give me any idea what to look for
@martijnpoppen
The units receive no new data, such as battery status. Homey reports they have not been detected for some time. This issue has occurred across three of my four devices, despite previous flawless operation.
@Daniel_Fille that I understand, but what kind of units are we talking about
Did you already try a repair. Etc etc
Report looks normal
@martijnpoppen
Sorry, two iPhones and a MacBook Air are involved. The repair didn’t resolve the issue; the devices only show “loading” with no further response. Restarting the app and the Homey didn’t help.
I removed all devices and added them again, so it works now , but if I’m not mistaken, I tried that a few weeks ago and the problem returned. I’m not certain .
I’ll send a new diagnostic if it occurs again—if it happens again.
This kind of trouble has never happened before, and I’ve used your excellent app for a long time.
@martijnpoppen My iPad the only one I had not re-added stopped updating its status once I restored the other devices, this is weird. If I re-add that iPad, the others halt again, so that is my problem. Everything works as it should in the iOS find my app.
@Daniel_Fille will investigate
@martijnpoppen Great! Thanks!
@Daniel_Fille Found it !
thanks for the detail about the iPad, that’s what gave it away. It’s a real bug: the app was matching devices to your Apple ID by a stored value that changes every time the app restarts, so devices added at different times ended up in separate groups and only one group got updated. Re-adding a device moved it into the working group and pushed the others out, exactly as you saw. Fixed in the next release; no need to re-pair anything once it lands.
New app update (
LIVE: 1.9.8):
Changelog:
NEW:
1: None
FIXES:
1: FIX: devices stopped updating after re-adding another device from the same Apple ID - every device on an account now refreshes together
Via Homey Webapp:
@martijnpoppen Thank you for the update and the clear explanation. The iPad updated its status after I installed the new version, though only once so far; it has now gone five hours. The others continue updating as expected—perhaps I should re-add it. Do you need a new diagnostic report?
