New update (Live: 2.4.2)
Changes include
- FIX: Refactor the cron time verification in pairing and settings forms.
- FIX: Pairing form “Add Device” button.
- FIX: new CronJob syntax changes due to updating to v3 cron
- FIX: Restore prettier formating
Changes include
Changes include
Thank you Peter Munch for the clear report submitted to Github.
@OH2TH, I use this great app to plan various things; it works really well.
However, I recently discovered a small error in the condition (and) cards:
Perhaps the Dutch translation is missing? (is = is | isn’t = is niet)
The problem is that when you add the card, you can’t see which if the ‘not’ is active on the card:
The top card (Is enabled) does work fine, but only the English term ‘isn’t’ still needs to be translated into the Dutch term ‘is niet’:
Thanks for noticing that, I will need to check that.
Thanks for the quick fix!
All the text in the Dutch cards are correct now, thanks!
Hello Tapio
I already use your app, and it is working awesome!
I have a suggestion for an addition I would like to put forward… would it be possible to add to the schedule card to include seconds? I have a number of advanced flows that trigger actions every so many seconds. Currently I am using the native time cards for Every 10 seconds, for example. But there is a bug (which apparently Athom is aware of but hasn’t managed to fix yet) that sometimes after a restart (either because of my weekly timed restart, or a firmware update) the time triggers don’t restart. You either have to reboot again, or go through all your timed flows and edit and resave them.
Your app seems far more reliable, but I couldn’t find an option for seconds?
Second / Minute / Hour / Day of Month / Month / Day of Week - would be nice to have.
Thank you for your time and consideration, greatly appreciated
Andy
