[APP] Philips Hue - Transform the way you experience light
Can I get this to work offline?
Now when my internet drops out all Hue lights stop responding.
Is there anything I can do to fix this?
Wanted to thank you for posting this solution! Got it working to activate a smartscene. Whenever the lux in the living changes and is above a certain value, homey will check if anyone is home and activates the according smartscene. When nobody is at home a similar flow is triggered.
I’ve read conflicting information about whether the Hue Tap Dial supports dimming lights with the dial ring through flows created in Homey.
Can anyone confirm whether this works or not?
It does, but it’s not stepless. You can’t bind it to a device using Homey.
I use it in my office to do 10% increments in either direction. Works fine for me.
I wish Athom would integrate hold functions for the Tap Dial buttons though, which is possible within the Hue app, but not with Homey.
Any idea if the Wired modules will be supported on the official Hue app of Homey? (not the one without the bridge)
According to the changelogs on 11th of aug the support for the wired module is supported, though I cannot add them to the app :face_with_spiral_eyes:
EDIT: I got in touch with Homey Support. They suggested me to try the test version of the Hue App for Homey. Most probably that will add the Wired Modules into the app. I will keep this thread updated with the findings and update
On Monday evening I upgraded my Philips Hue Bridge V2 to a Philips Hue Bridge Pro. After a restart of the official Homey Hue app all my Hue devices were discovered and worked fine. Very nice! However, this morning (Wednesday, less than 2 days later) the Homey Hue app reports “unreachable” for every device and when I try the repair function the app complains that the Hue Bridge cannot be found…
How can I get this working again?
(Without deleting everything; I have many devices/flows)
PS: Also contacted support with the same message, but maybe a fellow user has a solution?
Hi, I just moved from Home Assistant to Homey and mis some crucial option (crucial for me at least) in the HUE integration.
Feature Request: Support Double Tap and Hold on the Philips Hue Tap Dial Switch
Please add a dedicated Flow trigger for the Double Tap and Hold interaction on the Philips Hue Tap Dial Switch in the official Philips Hue app for Homey.
Expected functionality
  • Detect double tap and hold as a distinct button interaction.
  • Expose it as a separate Flow trigger for each of the four buttons (preferred button selection with action).
Technical reference Home Assistant already detects this interaction, demonstrating that the event can be captured and used for automations.
Use case This would allow Homey users to create additional automations without having to route the interaction through alternative external setups like Home Assistant in this case.
Hope this can be accomplished in Homey.
