[APP] Netatmo - Same home, just smarter. (by Athom)
Im trying to figure out, how to identify if a valve is on or off. I need it eg for opening windows, but dont want to open windows if the heat is on, for long.
Looks like this Valve is never On or Off, it is like most thermostats self regulating the temperature based on a Set Temperature, and only reports measured Temperature.
I would advise to set the Set_Temperature to fe 5 grC when the window is opened for fe longer than 60 seconds. and return to normal operation after closing the window.
Thanks, that could be a work around! Or I can just check to see if temperature is higher or lower than the target temperature.
I just think its strange, that I cant see if the valve is open or not. In the Netatmo App - Energy for iOS, you can see if each valve is letting hot water through or not. It was this property i wanted. And it most be available as the iOS can show it.
Can anyone explain why my app tells me it’s 19.6 degree celcius in my kids room. The Homey device tab shows a app from Netatmo with 19.6 degree celcius on. But when I run my flow. The value for temperture in the Netatmo app shows 23!!!
[Tip] Problems with Homey?
I have no idea as for me it is functioning normal
Homey Pro (Early 2023) v 1.0.9-rc1
NetAtmo App v5.4.3
NetAtmo Smart Home Weather Station - + 3 Additional Indoor Module
:grinning: :grinning:
Having problems with the Outdoor Module in Homey. Homey says that the device is unavailable, however it is online, and shows up everywhere else. If i remove the device from homey, and try to add again, then it shows up during the adding, but once it’s added it just says device unavailable. All other modules are working fine in homey
I have exactly the same Problem with the same module. If I restart the app it shows the correct data eg temperature for a moment and then breaks again.
Hi, anyone who knows / has Home coach… the app page seems to say that there is just one flow card - when for ”the health index changed” . Is that the case? No cards for the actual measurements such as temperature, co2, noise like the weather station has?
Don’t ask me why, but that is the case. I see it too in the app.
I have got the weather station. And got all the cards. I cannot test it for Home Coach.
Hello, volunteers have been sought for a new app development, see the link for more info if you have home control hardware
I’m having a problem where the app doesn’t update the data. I have to repair each device every day for it to get new data otherwise it doesn’t update the temperature or ppm and all other data. Anyone else had this problem?
Oooeh, still fun seeing the old flowcards whahaha
:laughing::grin::laughing:
Do anyone else experience major issues with the Netatmo radiator valves after the latest update (5.6.1 as of 10th of September)? HP2019. Replaced the old set mode (to program) cards with the new ones in all flows as per recommendations of the new version. The old card actually worked nicely, but the new ones output the following: Error nothing to update (code 406). I get the same error when trying to set temperature by flow-cards or in the device itself.
Tried PTP of Homey, Wifi-router and Netatmo relay.
All input appreciated. I have filed a bug report to Athom already, but would be interested to hear whether or not others experience this as well.
Best
I have the same problem. Support said the Homey had a firmware error and I should reinstall the firmware on the PC. I can’t say yet whether that will solve the problem, as it has been stuck during verification for 40 minutes.
Thank you for responding, keep us posted how it goes! To me it sounds like an issue with the app (across HP19 and 23, as I assume you are using 23?) as this update specifically amended code related to the Netatmo valves. Also the issues I have started immidently after the app update and nothing has happened to the HP19 firmware during this period. Really bad timing just when the heating season starts. Hope it will be fixed quickly and hopefully in a smoother way than requiring us to mess with re-adding devices, doing factory resets or reinstalling Homey’s firmware.
Yes, I use a 23. Firmware was not the problem, as expected. I also believe that the new Netatmo version is causing this bug. I am now waiting for support. I am also thinking about installing a backup from 2 days ago…
I have the same error with Natatmo valve after uppdate v5.6.1
The valve are visibel in Homey. But impossible to change target temperatur manuelly or by Flow
I can confirm that the issue is not related to the firmware on either Homey 2019 or Homey 2023. The problem is with app version 5.6.1 or the Netatmo API.
Here’s why I say this:
When I use the Netatmo app on Homey and, for example, try to use the “Set Mode” function, I get the following error:
Error: Nothing to update (Code 406)
When I use the Bticino/Legrand/Netatmo app and, for example, try to use the “Set Temperature” function, I get the following error:
406 Not Acceptable
However, here’s a solution that works, but it requires the following to be installed:
SmartThings Community app
  1. Add Netatmo to SmartThings.
  2. Import all your thermostats into SmartThings so you can see them there.
  3. Go to the SmartThings Community app on Homey and add your thermostats.
  4. Go to the Bticino/Legrand/Netatmo app on Homey and add your thermostats.
What options do you have then?
Through the SmartThings Community app on Homey, you can use the “Set the heating temperature” function to set the desired value.
Through the Bticino/Legrand/Netatmo app on Homey, you can use the “Set home to home schedule” function if you want to revert to the schedule you normally use.
thanks for the update
I’ll wait a week or so and see if it gets resolved.
Otherwise I use your workaround.
