hopefully soon I start messing with those setting,
Enrichments on the debt first time I read about that is that in the Govee App?
Thanks!
Thanks!
It’s per local api device an advanced setting in the homey. It uses all local api commands except when the feature is not supported locally, then it uses cloud api.
oh thanks!
Again thanks for making this App!
I’ve got a new Air quality sensor H5106. Is it possible to add this device to your Govee app?
Greetings,
David
Is it wifi or bt? If wifi you can use the cloud api test page to confirm it’s present and if you can pair it with the thermometer device send me the reasons from the api.
Bt you can use the bt test page, same story.
It’s using BT and WiFi. I used the “Test api & get devices”. The device is shown:
"sku": "H5106",
"device": "xx:xx:xx:xx:xx:xx:xx:xx",
"deviceName": "SZ Air Quality",
"type": "devices.types.thermometer",
"capabilities": [
"type": "devices.capabilities.property",
"instance": "sensorTemperature"
"instance": "sensorHumidity"
"instance": "airQuality"
I’ve paired the air quality monitor with an air purifier (H7124).
Does this help?
Yes, and it tells me it shows as a type thermometer, so you should be alive to add it to Homey as govee devices, group sensors, thermometer
Did you try that?
I got it! Thank you for this hint. It shows temperature and humidity, but not the pm2.5 value from that device. But it’s ok.
Thank you very much.
That capability seems new, so I’ll add it to my list, it will show if it’s in the data
Can you also do a get device state on the test page? Then I know what values the airQuality reports in what detail.
And you can try the test version
I found it an here’s the result:
"sku": "H5106",
"capabilities": [
"type": "devices.capabilities.online",
"instance": "online",
"state": {
"value": true
"instance": "sensorTemperature",
"state": {
"value": 69.8
"instance": "sensorHumidity",
"state": {
"value": 55.3
"instance": "airQuality",
"state": {
"value": 1
1 matches the reading in the govee app also?
yes that’s right. 1µg/m³ is correct and shown in the original iOS Govee app and on the display of the device too.
But after installing the test app I’ve got only one reading. It won’t update the last 22 hours:
The other readings for temperature and humidity are updated often. In the Govee app I found this chart for PM2.5:
The reading should have updated to 2 or greater at 7:00am until 9:00am. I’ll check this for the next days - not sure how to test this with the sensor.
Greetings,
David
Can you send me a diagnostic report? Then I can see if it changes in the API.
I am living for Govee, very oftenly Matter just broke, devices are not responsive. Sometimes restart of Homey is working, sometimes not.
I am happy not all.
Govee app is working, but I dont want to use phone app allways, when I need to turn lights on.
Maybe it is discussed already somewhere, this thread is quite long to find it out
Matter is Homey native so I do not have influence on that. So reach out to Athom or Govee support. This app is local api and cloud api and some experimental Bluetooth devices.
Device Request. I saw there is a beta for BLE devices. Would it be possible to support H167E. Currently when searching it does not find it
Use the ble test page in the app settings, see if it can locate it and get its broadcasts. If you can find it share them then I’ll give it a go
