[APP] Fibaro - Your home is your castle (by Athom)
I’m worried I might be the only one experiencing this issue, since I haven’t seen anyone else mention it.
I use scene activation on almost all of my switches, but since update 3.8.51 (April 2026), none of my switches seem to work anymore.
The flows themselves still work, but they are no longer triggered when I press the switches. I haven’t changed anything on my end. I’ve even created a few simple test flows, but none of the switches are activating them.
Power cycling everything didn’t help either.
Is anyone else experiencing this problem?
I can confirm this is happening on my end too. I use Dimmer 2 modules, and after the recent app update, the S2 triggers stopped working entirely. Like you, my flows are fine if I start them via the app, so the logic is there, it’s just the ‘Scene Activation’ that isn’t firing. Re-pairing the device didn’t fix it for me either, which suggests a deeper issue with the app version itself.
Ah, thanks for your reply. I tried deleting a Dimmer 2 and adding it again, but that didn’t solve the problem.
I guess we’ll have to wait for an update to fix this.
Made a report:
I’m having a similar problem with my Fibaro Walli Roller Shutters. The scene activation works with the upper switch, but not with the lower switch.
But are you sure it’s because of the Homey Fibaro update?
What version of Homey firmware do you, @0burner0 and @Eric_Perez, currently have installed?
I’m running v13.2.0-rc.2, and this firmware includes a lot of changes regarding Z-Wave integration.
Btw, I’ve already contacted Athom Support, though.
I’m running Homey firmware v13.2.0-rc.2 as well, with Fibaro app version 3.8.5.
To rule out hardware issues, I tested by toggling the ‘Swap input 1 and 2’ setting in the app. Since the physical button then worked fine for the other input, I’m certain the switch itself is functioning and the signal reaches Homey. The breakdown is happening specifically in the scene activation trigger afterward.
I have also reported this to Athom Support. You make a good point about the firmware; given the major Z-Wave changes in v13.2.0-rc.2, it’s very likely the root cause lies there. Hopefully, with multiple reports coming in, they can pin-point the bug quickly.
I can confirm the same issue with Fibaro Dimmer 2.
  • Physical input is working (signal present on S1/S2)
  • Light control works normally
  • No scene or multi-click events are received in Homey
I replaced the module with a newly ordered one, but the issue persists, so this seems unrelated to hardware.
Looks like a regression in Homey or the Fibaro app handling scene activation.
ATHOM REPLEY ON TICKET:
Hi ,
Thank you for reaching out to our support and for reporting this issue. Our apologies for the inconvenience!
This issue is a known issue at the moment and also has been reported by other Homey-users.
I can’t give any guarantees on when this issue will be resolved, but please know that this issue is under investigation. We hope to resolve this issue as soon as possible.
Thanks again for your input and for reporting the issue, we appreciate it!
For now this is all I can do for you as support, which is why I’m closing your ticket.
I wish you a great day!
Best regards,
Niels
It’s pretty much a standard response, but okay.
That was my response from Athom Support:
Of course, “healing” the devices in Developer Tools doesn’t help, since the Fibaro Walli Roller Shutters otherwise work without any issues—scene activation even works with the top button, just not with the bottom one.
And of course, I haven’t deleted the Fibaro app either. I’ll wait and see if they respond to my follow-up questions.
Edit
These are my follow-up questions:
And this is the answer from Athom support:
Just for info!
I also have this issue.
Previously, scene actions (multi-clicks, button presses) on my Z-Wave dimmers were working correctly in flows, but recently they stopped working completely. I did not change any device parameters or configurations.
I have multiple dimmers of the same type, and scene activation is not working on any of them.
At the same time, I started seeing repeated errors in the log:
id=“k2x9qp” [zwave:pro] error handling command from node 118.0, command=56012b011a0094c3 unsupported command class COMMAND_CLASS_SCENE_ACTIVATION (43)
This is happening across all my dimmers, not just a single device, which suggests it may be related to a recent Homey or app update rather than individual device configuration.
From what I can see, the devices are still sending Scene Activation commands, but Homey no longer handles them, so the corresponding Flow triggers are never fired.
Has support for COMMAND_CLASS_SCENE_ACTIVATION (43) been removed or changed recently?
Is there a recommended way to restore functionality without reconfiguring all devices?
Any insights would be appreciated.
If your Homey is running version v13.2.0-rc.1 or -rc.2, then this is a known issue. Athom has already been informed about this by several users. The issue may be resolved in a future firmware update.
There is a beta/test version.
Hope that this solves the issue.
Keep you posted
Did not solve the problem
I think we’ll have to wait for a new firmware update.
New firmware today: 3.8.6
The issue with SCENE_ACTIVATION has not been resolved.
A new firmware update, v13.2.0-rc.5, was released for Homey Pro/min about 2 hours ago.
Changelog regarding Z-Wave:
Z-Wave
  • Various bug fixes for regressions introduced in v13.2.0.
Scene Activation still isn’t working for me. How is it working for you?
Edit
I have to revise my statement. Scene Activation is working again after all. Sorry!
Works for me now, since this morning…
Here the same, It’s working again :slight_smile:
Hi everyone,
I’ve been experiencing this issue for about 4 weeks now, including with the previous firmware updates.
Today I updated again to the latest Homey version, but unfortunately the problem is still not solved.
The issue is with my Fibaro Double Relay Switch 2 modules:
  • Only the second switch/channel stops working
  • The first channel works perfectly
  • I have around 6 identical modules
  • All of them show exactly the same behavior
Current Homey version:
  • 13.2.0
At this point it really seems related to either the Z-Wave implementation or the Fibaro app/firmware compatibility.
Has anyone found a stable fix or workaround yet?
And what is the best way to report this directly to Homey/Homey support?
In the Homey App Store, there is a link to contact Athom support:
