[APP] Fibaro - Your home is your castle (by Athom)
Yes it’s working again
Homey fw 13.2.1rc4
Hi everyone,
I’m experiencing an issue where I cannot remove associations from my Fibaro device in Homey. My goal is to completely disable the direct associations between the device and several lamps, but the associations seem to remain active no matter what I do.
I’ve tried changing the association values and then immediately recalibrating the device, but unfortunately that didn’t solve the problem. I don’t receive any error messages, and the new values are saved successfully. In the settings, groups 2 through 5 show a “-” as expected, which suggests that the associations have been removed.
However, the lights still continue to react to each other as if the associations are still active.
Has anyone experienced this before? Is there a way to force these association values to be applied to the device? Could the device be caching the old associations somehow?
I’m curious if anyone is familiar with this issue or, even better, has already found a solution.
Thanks in advance for any suggestions!
And the same problem again :confounded_face:
13.3.0-rc.16
Fibaro Switch is not sending status to homey, if activated by connected physical switch.
Since a few days, i have a strange behaviour. i use some fibaro switches behind the original physical switches. Works fine since years.
Not, for one switch, the physical switch is still activating the light, so the fibaro is reacting, but homey does not reflect the status.
If i switch from homey on/off, no problem.
Zwave connectivity is show as errorless.
any ideas where to start debugging?
Anyone starts having problems after installing recent Fibaro | Homey ?
3.8.13
7. 8. 2026 - Fixed issue where walli switch in single mode would error when toggled
Even it’s not mentioned in the changelog and I would not expect that one of 6 would behaving like this, one of my FIBARO Roller Shutter 3 FGR-223 start misbehaving very oddly and calibration is not improving anything. Basicallly I can’t use TILT function, it’s actually acting partially as POSITION suddenly.
To be honest, I don’t know what kind of mess Athom has made with the Fibaro app!
Just have a look at this topic → Problem with Fibaro Walli Switch
But I’m still not entirely sure whether the problems started with the version 3.8.10 of the Fibaro app and/or with the latest Homey firmware v13.4.0 update.
For me it started with Homey 13.4.0, when the S1 side of my Dual Switch 2 devices stopped reporting status changes. Athom’s advice was to remove and re-add the devices. That did fix it, but it’s easier said than done when you have a dozen of them and a lot of flows built around them. Not to mention Homey does not support network wide inclusion so I had to move Homey close to each of those switches.
So yeah, pairing it again did resolve the issue. But this is quite strange this is happening, while changelog did not mention anything on this device.
I don’t like the fibaro devices at all…some worked fine for years but the smoke detectors lost connection all the time. I had the HC2 but it was not reliable so I moved to Homey.
Fibaro Dimmer 2 : status indicator grey and not able to change the status indicator. I have several Dimmers some are okay with regard tot the statusindicator and some not.
