Correct, I use homey cloud with homey bridge hardware.
Will the feature move soon from a testing to an official version to also prevent locking issues within the released version (users in development vs official release) ?
This mornings release version has the âfixâ, but it takes a bit of time to roll out. As of an hour ago when I looked, just over 7000 Homeyâs had updated but I canât see what the split is between Pro and cloud and there are still nearly 1000 to go. Hopefully it will resolve in about 24 hours.
OK, if you have a devices called âKjøkkenâ, âStuevinduâ then it will be added with the âExterior blind (io)â or âVerticale buitenzonwering (io)â device.
Those are the names of the devices. Unfortunately when trying to add them as âExterior blind (IO)â, I get the response âNo new devices foundâ. I canât find a device called "Verticale buitenzonwering (io)â.
The only thing Iâm able to add is the Switch itself.
That is just the Dutch text for the same thing, as I wasnât sure what language your Homey is using.
You are not the first one to have this issue, but I havenât been able to get to the bottom of it yet. When I run the log through my simulator (I feed the log data into the app as if it has come from Tahoma box), it all works fine and I can add the devices (I canât test they actually work as I donât have access to them). So I canât see why they donât show up for some of you as the data Iâm using is coming from you.
Maybe you could enable the Information Log, then try to add them and when it shows no devices, go back to the Information Log and send it. Maybe it will highlight an error that Iâm not seeing.
I send to you my journal regarding a problem with the connection to my Tahoma. I use the Version test v4.0.33 and the reply is
âtimeâ: â2023-06-13T19:45:37.970Zâ,
âelapsedâ: 0.378,
âsourceâ: âLocal loginâ,
âdataâ: âError: queryAaaa ENOTFOUND gateway-2014-9483-9193.localâ
Information log sent. I tried adding the devices (with the same result as before) about 20 seconds before sending the log, so it should be near the bottom.
Hmm, something strange going on as in the Information log the âStuevinduâ is showing up with âcontrollableNameâ: âio:AwningValanceIOComponentâ and that is the âAwning / Pergola (io)â device.
In the previous Device log it shows up as âcontrollableNameâ: âio:VerticalExteriorAwningIOComponentâ which is the âExterior blind (io)â device.
The only thing I can think of it that there is an inconsistency in the local and cloud definitions.
So, could you try adding them using the âAwning / Pergola (io)â device to see if that works?
OK, I found the report but it is very limited, so doesnât show anything useful.
Could you open the App Settings page, select the Information log tab and enable the log.
Then run your flow and go back to the page and tap on Send Log.
Getting the timing right might be tricky as the log has a limited size due to memory constraints, but sending that many commands will take a bit of time. If you see information scrolling off the top of the log then you might have to send it a few times to capture all the commands.
