[APP][Cloud & Pro] Somfy Tahoma & Connexoon (v4.0.81, test v4.0.84)
Thanks a lot :slight_smile: that helped :slight_smile:
Hi Adrian,
I’m running 4.0.94. It was updated 28-Sept. Now It keeps crashing during the night.
When restarting it works again, but crashed some hours later.
I’ve tried to reboot Homey (Pro’19), I have updated the Somfy Connexoon box, restart etc. with no luck.
I’ve just sent you a diagnostics report :slight_smile:
I started having issues last month with my Pergola control.
When trying to send commands through Homey about opening or closing, I now immediately recieve the error message “Request failed with status code 400”.
I have tried to remove the device from Homey and added it again. I have also tried to update the app to latest test version (v4.0.95).
It is still possible to control it via the Tahoma system.
I’ve just sent a diagnostics report (Device log ID: 1394453237) as well as the event log, where I triggered the Pergola opening from the Tahoma system.
Can you tell me what might be the issue?
The log is not showing any errors so I can’t sat what the issue is.
maybe you could send the log again after you see the error code.
Hi Adrian,
Thanks for the quick reply.
However, the thing is it doesn’t write anything in the log about the action and error.
I have attached a screenshot that shows the empty log even though I made an action to open the pergola?
You need to look at the information log tab and make sure that log is enabled.
I cleared the information log, triggered the error 400 by when setting the closure to 51% and afterwards 40%.
Just sent you the information log (1394453237)
Strange as there is still no errors in the log.
Is the pergola moving?
Maybe wait longer before sending the log to ensure it has captured all the events.
Also, try restarting the app to see if it clears the error.
I tried to restart Homey, restart the app and waited 45 seconds before stopping the log (just sent). However I still don’t see any error being captured.
The pergola is not moving.
I get the 400 error as soon as I tap the Pergola card (in yellow) and once again when I change the closing value (in red)
I am new to the Tohama switch. Can anyone share experiences about:
  • what is the recommended average lux value to lower an outdoor screen?
  • how to deal with a wind sensor that raises the screens and the associated temporary blockage
  • an example of an (advanced) flow to make the screen respond to sunlight without a yo-yo effect.
@Adrian_Rockall Could you give me any advice regarding my questions above?
Thank you in advance.
I can’t give much advice. The value depends on where the light sensor is placed. I have mine in a south facing window, so gets full sun. I then set a value of less than 180 to close the curtains at night and greater than 200 to open them in the morning. But I also have time limits, so they don’t close before 4pm or open before 8am.
It took me a while to get the Flows as I wanted them as I also open the patio door curtains if the door opens and close them when the door closes again, plus different times for the bedroom blind as my wife lays in.
I don’t have a wind sensor or awnings, etc, so can’t advise on those.
Hi all,
On the main page of tahoma (Somfy TaHoma & Connexoon App voor Homey | Homey)
stands the danfoss icon room thermostat should be able to connect to the tahoma app. How can i fix this connection?
I have the somfy tahoma switch already.
It seems like it should be able to connect the 088U1081 Danfoss icon thermostat.
Already many thanks!
Did you solve the issue? I’m trying to do the same without success…:frowning:
Have you sent me a device log from the app settings page?
Hello Adrian,
Yes I did times ago :slight_smile: I sent you again, the device I need to add is a Somfy thermostat.
“ Log sent successfully. Please contact @Adrian_Rockall on the forum with the log ID: 926070211 and explain the issue”
Thanks you
Marco
OK, I can see the device with “controllableName”: “somfythermostat:SomfyThermostatThermostatComponent”.
Unfortunately, I haven’t added the device to the Homey app yet and it doesn’t fit in with the other thermostat device as it has different commands and status names. So I need to create a new driver for it, which I will do as soon as I can.
Thanks Adrian for your feedback! Is the last device I need to connect to complete all Somfy devises on homey :slight_smile:
Have a nice day
Marco
Hi everybody!
Hope someone can help me resolve this issue. I have recently connected my Tahoma gateway to my Homey Pro.
I can add window screens without any problem, but my garagedoor opener is nowhere to be found when I try to add it to Homey.
It’s added in the Tahoma app but when i try to connect it to Homey it can’t find anything to add.
Is there something I’m missing?
Garagedoor-openers is listed in supported devices in the Homey App, but not the different models.
Dexxo Compact 750 io
select ‘Add device’
select ‘Somfy Tahoma and Connexoon’
search : ‘io’
try all :roll_eyes:
Took me some tries to find the correct one. Don’t look at the names, it’s the kind of motor that makes it work (or not)…
