[APP] Batrium
Batteries Made Smarter
https://www.batrium.com/
App Store Page
https://homey.app/a/com.batrium
Description
Bring data from your Batrium Watchmon into your Homey.
Requirements
This app relies on the Batrium UDP datagrams that are generated when it is connected to wifi and broadcast is set to On and Verbose.
The setting is reached via Hardware → Integration in the Watchmon Windows app.
I’m using the latest Watchmon firmware version as of the end of March 2021, which the app is tested on.
Watchmon device type
Capabilities
  • Power
  • Shunt current
  • Status
  • Battery SoC
  • Shunt volt
  • Remaining capacity
  • Min cell volt
  • Max cell volt
  • Min cell temp
  • Max cell temp
  • Charge rate state
  • Discharge rate state
  • Cumulative charge
  • Cumulative discharge
Triggers
  • Status changed
  • Charge rate state changed
  • Discharge rate state changed
  • Maximum cell volt difference changed
  • SoC changed
Conditions
  • Status is
  • Battery SoC is
  • Maximum cell volt diff is
As usual, any feedback is welcome :smile:
I see I got a few installs of the app :slight_smile:
The next version due to be approved by Athom is not backwards compatible I’m afraid - so you will have to remove the Watchmon device and add it again after you get version 0.9.2. Decided to do some refactoring of capability names, etc upfront.
