You could have just accepted the logic card solution gracefully. I was only trying to help.
Ik already accepted the Logic card solution provided by @DirkG, before jou stated the cards didn’t chance.
Don’t worry I shall not bother you again
Indeed. And that was what I mentioned in my earlier reply to your post. That card does not exist anymore, because the battery alarm-capability was removed. As the developer indicated, that requires updating flows that uses that specific card.
By the way: you can use the Flow Checker app to quickly identify broken flows, so that you don’t have to go through each and every flow manually.
Oh yes, sorry, it was you who pointed me to the release note, not DirkG. DirkG gave me the Logic Card solution.
Thanks
Interesting, so maybe the firmware version 0.0.0_0032 causes the issue.
Maybe that’s why you should contact Aqara directly. Otherwise, I have no idea who could solve this problem or how.
@Drako74 Did try to send you a DM, but you don’t except these. Is there an other way to contact you off-topic?
I did more than drink coffee: I waited a full day to put the battery back. And did a reboot. Same result unfortunately.
Unfortunately, the wirelss mini switch model: WXKG20LM will not pair after the update. I have changed batteries, restart the homey pro, verified everything was up to date, tried pairing via phone and computer. I got this to connect in the past but for some reason it will not pair this go around. Any tips?
hi, I updated one of my homey pro to the latest OS and aqara 1.19.1 .bad idea. I switched it off during the weekend and lost connection to my sensors mondaymorning . Worse, I can’t pair the windows sensors , I have older versions and new ones (with battery shield). after one hour trying one connected. tried to add them on other homey with 1.16.2 that works. if I could load 1.16.2 then I could be happy.
@TedTolboom Hi, W600 again. Is it possible to use the "Thermostate running state’ or ‘valve position (above 0%)’ to indicate heating (the visual feedback in apps through orange and tile icon)? I frequently see that homey indicates no heating, while the radiator is actually heating and running state is ‘heating’ and valve position is above 0% (false negative). App V 1.19.2 Test.
The fact that it heats despite the Temperature being above the Target Temperature is related to the crazy hysteris this valve insists on using (in the picture the temp is on its way to 23 degrees before it closes the valve, deliberately by me set to 21 degrees to actually reach the desired 23, if set to 23 it would go to 25 and so on. Two degrees makes a massive difference in a house from 2011 built for heat preserving and winter conditions, it gets crazily hot!). This weird hysteris understandbly seems to confuse Homey, but may be sort of solved/worked around by the suggestion above?
Hi! How many Zigbee routers do you have in your network? I have around 30 and recently had a similar pairing issue with an Aqara temperature and humidity sensor (lumi.weather).
I captured the Zigbee traffic and could see the routers advertising that joining was allowed, but the sensor wasn’t proceeding with the join. It eventually paired through a Philips Hue bulb acting as a router.
If you have lots of routers, you could try temporarily unplugging most of them and pairing the switch close to Homey. You could also try pairing near a different router. I’m not sure whether your WXKG20LM has the same underlying issue, but it may be worth a try.
Try the method in the message above
Hi @TedTolboom, My H2 EU switches still behave like before. Maybe they have gotten a tad bit better after the 1.19.1 update (or maybe it is placebo), but button presses still register and then dont register intermittent. 5 presses can trigger flows in a row and then 1 to 10 presses does nothing. Very randomly every time.
As before the one i tried connecting with ZB to aqara hub and then matter to homey registers every press all the time.
Cheers!
At what rate are you testing the button presses? There is a 1 second debounce time implemented to prevent duplicate messages to trigger the same scene multiple times…
I’m not able to control how Homey displays the thermostat. I already added the thermostate running state (derived from the valve state)..
Can you try adding the SD-S01D version to Homey and share the productID when it is added as standard Zigbee device?
LUMI
lumi.sensor_smoke.acn03
That combination is already supported in the Aqara app. It is identical to the SD-S01E.
Finally! Last devices is over to Homey and now I can get rid of the Aqara Hub :blush: thank you!
