This app is for Zigbee devices.
Ok. There is no app for bluetooth that I am aware of (except Xiaomi Mi Flora)?
That’s correct, so the best place to post a request for support is this thread.
Thanks :slight_smile:
Apologies: there is an app for Xiaomi BLE. Support for your device has been requested already but I guess it never materialised.
Version 1.10.0 is now live in the app store.
When is the Cube T1Pro integration planned?
Soon. (v1.10.1)
Finalizing the integration for the Cube T1 Pro; as in testing if the last actions (unique to the Cube T1 Pro) are working correctly.
Thank you very much for the work that is being done!
Many thanks for all the energy and effort!
Small note: the change log mentions the “Dual relay module T1 (DCM-K01)” but this should be “…T2…”
Ik heb daar ook last van maar wanneer je een nieuwe batterij erin steekt gaat het weer een poosje goed. Blijkbaar moet het een heel sterksignaal geven/ ontvangen om goed te blijven werken.
Hi Ted, I’m having this issue with the T1 Door and Window Sensor too. The T1 door and window sensor pairs to homey, but does not report the battery status or connection status. In developer tools it says the value for both is “null” where the non-T1 Aqara Door and Window Sensors have a “false” value (as in there is no contact alarm). I have 4 T1 sensors, all work when paired with an Aqara Hub, but not with Homey 2019.
aqara water leak sensor t1 not working in homey 2019 does anyone know how to fix it or have you given up? they can get into homey but they don’t work
It looks like it is supported at least in the latest App version. Have you installed that ?
yes, I’ve installed it, unfortunately, but it doesn’t work, have other aqaras that just don’t work, the leak sensor
I will try to reproduce the T1 issues on the HP2019 in the next days.
Thank you hope it will works soon​:pray::pray::pray:
Does anyone have problem with RTCGQ11LM motion sensor after the battery depleted? I did replace the battery and then the sensor only working 1-2 time in a day. Before this it was perfect. I have 2 of these right now
True, and indeed this is my setup. I really do not know why I wrote that! My bad!
The Bridge is connected to the Homey Pro 2023 in sattelite mode, sorry for not posting this in the first place.
