You are not publishing any new and unknown information with your investigations and your commentary on them. Therefore I would like to respond to some of your points and add some information that you may not yet know.
  • Only on/off works with Matter
    Measurement of power consumption is not yet included in the current Matter specification version 1.2. So it has nothing to do with Homey.
  • There should be no need for additional hubs
    This is probably what all Homey owners want, but unfortunately in general it’s not possible in reality yet (currently not related to Aqara, but see comment at the end).
    Some manufacturers of smart home devices use a proprietary code to communicate between their own hubs and their own devices. This code is not published. Therefore it’s not possible to connect devices from this manufacturer to an open Smarthome system. The only way is that the manufacturer provides a so-called API (application programming interface). This allows other smart home systems to communicate with the hub of the manufacturer.
    What has this todo with Aqara in general? The latest information indicates that Aqara is moving further and further away from the Zigbee standard. This is why there are currently also problems implementing new devices in the Homey Aqara app. One possible reason for this could be that they want to sell their own hub (speculation!).
By the way, it almost never happens that an Athom employee comments on a problem in the forum. Therefore you can assume that Athom is taking the problem with the energy measurement problem seriously and is doing everything possible to correct this bug in the firmware. Unfortunately, it was a very bad time when this happened.
I can now confirm that my Aqara Single Switch Module T1 report watt.
Sorry if this has been discussed…
Lately I’ve been running into issues with my Aqara motion sensors (OG, not the P1 version). Where before they were 100% accurate in detecting motion, now it sporadically does so. What is strange is that, even though no motion is triggered, it does update the Lux, meaning that it has a connection and an actual motion was noticed (since aqara motion sensors don’t update lux without motion).
I’ve tried repairing, removing and re-adding but the behavior remains.
It’s not for all motion sensors but once the issue is seen it remains.
Hope above makes sense…
This is what it shows on the device when it updates lux but motion has not been triggered;
Appreciate your thoughts!
Yes lately I have the same problem. Have tried some things but no succes. Read some things about the power supply of the HW2023 so I took an apple power supply
for testing I ordered a P1 version of the sensor
Let me know if a different power supply helps but I believe I received a replacement already from Homey right at the beginning due to low voltage issues. Or is this on top of that?
no I have not received a replacement. Just trying something. I’ve also let my router search foar the best wifi channel hoping it will not interfere with other channels aquara is using
I guess for me this problem started after a power outage. Once power came back after a couple of hours it took a while but now (weeks later) they still show these symptoms. Weird part is that they do update homey once motion is triggered but just Lux… which wouldn’t make sense as Lux is only updated on the motion sensors when motion is detected.
Regarding the replacement adapter, those were only for the early buyers (pre-orders) in the first batch. Everything after should have the right power adapter.
Hi, thank you for your great work!
There is a function, that I cannot solve by myself.
There is a possibility in Xiaomi/Aqara Home app, that the wall switches could be changeable to Wireless switches. I would use this function because of the LED controllers I’m using. (then the switches will be “all ON” and just the remote signal travelling through the network. But if I would use the “always on” function in Homey, then the switch will be capable to use manually, what is a problem)
What do you think, could it be inplemented sometime?
@TedTolboom, first off; happy new year.
Was wondering if you could possibly jump in and provide your expert thoughts on behavior seen above. the behavior pops up only on 2 of my 15+ motion sensors and there’s no way to resolve it (tried repairing, re-adding, adding it to the Aqara Hub and then back to Homey). When I press the connect button it immediately is able to trigger the “motion” for a couple of times but after that it becomes very rare that motion is triggered. However, all Lux updates come through accurately and successfully so it does appear to have a proper zigbee connection.
Hi, I have same issue, with T1 sensor (temperature and humidity), homey app is not able to detected properly this device, and add it as Zigbee comon device, but I can do nothing with, is it the same issue that you are reporting ?
T1 sensors are not supported (yet), read this.
Indeed the same, athom said they will probably release a fix on their end this month, so lets wait for the announcement!
Just to be sure, that will also apply to the T1 Pro Cube?
Correct.
I just published v1.7.2 to the app store (test environment): Aqara App for Homey | Homey
This version should fix (by adding fall back options) the power and energy reporting for the Aqara switches / plugs.
If power and energy is not reported properly, please send an app diagnostics report (settings > apps > Aqara > send diagnostics report) and share a device interview result (Homey Developer Tools > interview devices)
TED, great to see this attempt ! Thank you ! Seems to be working, just observed this glitch for one of the socket :
hood
(but 1st I saw something like 1.6W, now I see 0.8W, which was exactly like before - I admit those are very low consumptions)
Now I see 2nd one :
ChristmasLED
(it was reporting 22W before - when I turned it off-on, it again reports 22W)
Diag. ID : 8c7b7fb4-0d34-4438-ac6d-985e158a0de1
Interview data (sharing for both sockets, seems to be different slightly) :
  "ids": {
    "modelId": "lumi.plug.maeu01",
    "manufacturerName": "LUMI"
  "endpoints": {
    "ieeeAddress": "54:ef:44:10:00:15:8a:55",
    "networkAddress": 19691,
    "manufacturerName": "LUMI",
    "endpointDescriptors": [
        "status": "SUCCESS",
        "nwkAddrOfInterest": 19691,
        "_reserved": 26,
        "endpointId": 1,
        "applicationProfileId": 260,
        "applicationDeviceId": 81,
        "_reserved1": 1,
        "inputClusters": [
          0,
          2,
          3,
          4,
          5,
          6,
          64704
        "outputClusters": [
          10,
          25
        "_reserved": 10,
        "endpointId": 21,
        "_reserved1": 1,
        "inputClusters": [
          12
        "outputClusters": []
        "_reserved": 10,
        "endpointId": 31,
        "_reserved1": 1,
        "inputClusters": [
          12
        "_reserved": 10,
        "endpointId": 242,
        "applicationProfileId": 41440,
        "applicationDeviceId": 97,
        "_reserved1": 0,
        "inputClusters": [],
        "outputClusters": [
          33
    "deviceType": "router",
    "receiveWhenIdle": true,
    "capabilities": {
      "alternatePANCoordinator": false,
      "deviceType": true,
      "powerSourceMains": true,
      "security": false,
      "allocateAddress": true
    "extendedEndpointDescriptors": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0,
                "name": "zclVersion",
                "value": 3
                "acl": [
                  "readable"
                "id": 1,
                "name": "appVersion",
                "value": 32
                "acl": [
                  "readable"
                "id": 2,
                "name": "stackVersion",
                "value": 2
                "acl": [
                  "readable"
                "id": 3,
                "name": "hwVersion",
                "value": 1
                "acl": [
                  "readable"
                "id": 4,
                "name": "manufacturerName",
                "value": "LUMI"
                "acl": [
                  "readable"
                "id": 5,
                "name": "modelId",
                "value": "lumi.plug.maeu01"
                "acl": [
                  "readable"
                "id": 6,
                "name": "dateCode"
                "acl": [
                  "readable"
                "id": 7,
                "name": "powerSource",
                "value": "mains"
                "acl": [
                  "readable"
                "id": 65533,
                "name": "clusterRevision"
            "commandsGenerated": [],
            "commandsReceived": [
              "factoryReset"
          "deviceTemperature": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0,
                "name": "currentTemperature",
                "value": 23
                "acl": [
                  "readable",
                  "writable"
                "id": 16,
                "name": "deviceTempAlarmMask",
                "value": {
                  "type": "Buffer",
                  "data": [
                    2
                "acl": [
                  "readable",
                  "writable"
                "id": 18,
                "name": "highTempThreshold",
                "value": 65
                "acl": [
                  "readable",
                  "writable"
                "id": 20,
                "name": "highTempDwellTripPoint",
                "value": 3
                "acl": [
                  "readable"
                "id": 65533,
                "name": "clusterRevision",
                "value": 1
            "commandsReceived": []
          "identify": {
            "attributes": [
                "acl": [
                  "readable",
                  "writable"
                "id": 0,
                "name": "identifyTime",
                "value": 0
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
              "identifyQuery.response"
              "identify",
              "identifyQuery"
          "groups": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0,
                "name": "nameSupport",
                "value": {
                  "type": "Buffer",
                  "data": [
                    128
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
              "addGroup.response",
              "viewGroup.response",
              "getGroupMembership.response",
              "removeGroup.response"
              "addGroup",
              "viewGroup",
              "getGroupMembership",
              "removeGroup",
              "removeAllGroups",
              "addGroupIfIdentify"
          "scenes": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0
                "acl": [
                  "readable"
                "id": 1
                "acl": [
                  "readable"
                "id": 2
                "acl": [
                  "readable"
                "id": 3
                "acl": [
                  "readable"
                "id": 4
                "acl": [
                  "readable"
                "id": 5
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
              0,
              1,
              2,
              3,
              4,
              6,
              64,
              65,
              66
              0,
              1,
              2,
              3,
              4,
              5,
              6,
              64,
              65,
              66
          "onOff": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "onOff",
                "value": true,
                "reportingConfiguration": {
                  "direction": "reported",
                  "attributeDataType": 16,
                  "minInterval": 0,
                  "maxInterval": 65535,
                  "status": "SUCCESS"
                "acl": [
                  "readable"
                "id": 16384
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
              "setOff",
              "setOn",
              "toggle"
        "bindings": {
          "time": {},
          "ota": {}
      "21": {
        "clusters": {
          "analogInput": {
            "attributes": [
                "acl": [
                  "readable",
                  "writable"
                "id": 81,
                "name": "outOfService",
                "value": false
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 85,
                "name": "presentValue",
                "value": 0.9480000138282776,
                  "status": "UNREPORTABLE_ATTRIBUTE",
                "acl": [
                  "readable",
                  "reportable"
                "id": 111,
                "name": "statusFlags",
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "acl": [
                  "readable"
                "id": 256,
                "name": "applicationType",
                "value": 589824
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
        "bindings": {}
      "31": {
        "clusters": {
          "analogInput": {
            "attributes": [
                "acl": [
                  "readable",
                  "writable"
                "id": 81,
                "value": false
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 85,
                "value": 3.093804121017456,
                "acl": [
                  "readable",
                  "reportable"
                "id": 111,
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "acl": [
                  "readable"
                "id": 256,
                "value": 720896
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
        "bindings": {}
      "242": {
        "clusters": {},
        "bindings": {}
  "ids": {
  "endpoints": {
    "ieeeAddress": "54:ef:44:10:00:85:4b:03",
    "networkAddress": 32653,
        "nwkAddrOfInterest": 32653,
        "_reserved": 26,
        "endpointId": 1,
        "_reserved1": 1,
        "inputClusters": [
          0,
          2,
          3,
          4,
          5,
          6,
          64704
        "outputClusters": [
          10,
          25
        "_reserved": 10,
        "endpointId": 21,
        "_reserved1": 1,
        "inputClusters": [
          12
        "_reserved": 10,
        "endpointId": 31,
        "_reserved1": 1,
        "inputClusters": [
          12
        "_reserved": 10,
        "endpointId": 242,
        "_reserved1": 0,
        "outputClusters": [
          33
    "capabilities": {
      "deviceType": true,
      "security": false,
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0,
                "value": 3
                "acl": [
                  "readable"
                "id": 1,
                "value": 43
                "acl": [
                  "readable"
                "id": 2,
                "value": 2
                "acl": [
                  "readable"
                "id": 3,
                "value": 1
                "acl": [
                  "readable"
                "id": 4,
                "value": "LUMI"
                "acl": [
                  "readable"
                "id": 5,
                "name": "modelId",
                "acl": [
                  "readable"
                "id": 6,
                "name": "dateCode"
                "acl": [
                  "readable"
                "id": 7,
                "value": "mains"
                "acl": [
                  "readable"
                "id": 13
                "acl": [
                  "readable"
                "id": 65532
                "acl": [
                  "readable"
                "id": 65533,
              "factoryReset"
            "attributes": [
                "acl": [
                  "readable"
                "id": 0,
                "value": 20
                "acl": [
                  "readable",
                  "writable"
                "id": 16,
                "value": {
                  "type": "Buffer",
                  "data": [
                    2
                "acl": [
                  "readable",
                  "writable"
                "id": 18,
                "value": 65
                "acl": [
                  "readable",
                  "writable"
                "id": 20,
                "value": 3
                "acl": [
                  "readable"
                "id": 65532
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
          "identify": {
            "attributes": [
                "acl": [
                  "readable",
                  "writable"
                "id": 0,
                "value": 0
                "acl": [
                  "readable"
                "id": 65532
                "acl": [
                  "readable"
                "id": 65533,
                "value": 2
              "identify",
              "identifyQuery"
          "groups": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0,
                "value": {
                  "type": "Buffer",
                  "data": [
                    128
                "acl": [
                  "readable"
                "id": 65532
                "acl": [
                  "readable"
                "id": 65533,
                "value": 3
              "addGroup",
              "viewGroup",
              "removeGroup",
              "removeAllGroups",
          "scenes": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0
                "acl": [
                  "readable"
                "id": 1
                "acl": [
                  "readable"
                "id": 2
                "acl": [
                  "readable"
                "id": 3
                "acl": [
                  "readable"
                "id": 4
                "acl": [
                  "readable"
                "id": 5
                "acl": [
                  "readable"
                "id": 65532
                "acl": [
                  "readable"
                "id": 65533,
                "value": 3
              0,
              1,
              2,
              3,
              4,
              6,
              64,
              65,
              66
              0,
              1,
              2,
              3,
              4,
              5,
              6,
              64,
              65,
              66
          "onOff": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "onOff",
                "value": true,
                  "minInterval": 0,
                  "status": "SUCCESS"
                "acl": [
                  "readable"
                "id": 16384
                "acl": [
                  "readable"
                "id": 65532
                "acl": [
                  "readable"
                "id": 65533,
                "value": 2
              "setOff",
              "setOn",
              "toggle"
        "bindings": {
          "time": {
            "attributes": [],
          "ota": {}
      "21": {
        "clusters": {
          "analogInput": {
            "attributes": [
                "acl": [
                  "readable",
                  "writable"
                "id": 81,
                "value": false
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 85,
                "value": 24,
                "acl": [
                  "readable",
                  "reportable"
                "id": 111,
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "acl": [
                  "readable"
                "id": 256,
                "value": 589824
                "acl": [
                  "readable"
                "id": 65532
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
        "bindings": {}
      "31": {
        "clusters": {
          "analogInput": {
            "attributes": [
                "acl": [
                  "readable",
                  "writable"
                "id": 81,
                "value": false
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 85,
                "value": 5.1722211837768555,
                "acl": [
                  "readable",
                  "reportable"
                "id": 111,
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "acl": [
                  "readable"
                "id": 256,
                "value": 720896
                "acl": [
                  "readable"
                "id": 65532
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
        "bindings": {}
      "242": {
        "clusters": {},
        "bindings": {}
Hello
It is impossible to connect the E1 hub to the Homey box. Do you have a solution?
Alexandre
Thanks for the fast feedback.
Added an additional debug line to the diagnostics code to understand where this glitch is originating from in v1.7.3. If you see this again, please submit a new diagnostics report.
Great news ! So far this seems to function well with my plugs.
