Anyone using Deconz with Conbee II in Synology NAS?
Is there anyone who’s running Zigbee devices using Deconz with Conbee II plugged in a Synology NAS.
I’m trying to figure it out, but I’m stuck
I tried to, couldn’t get it to work (using a VM)
Now using it on a Raspberry Pi with Zigbee2mqtt
If you’re using DSM7, you need to install some kernel drivers that Synology has removed (:face_with_symbols_over_mouth:). I have built a set of drivers which can be found here: GitHub - robertklep/dsm7-usb-serial-drivers: Synology DSM 7 USB serial drivers
Another source for those drivers is this site: Index of /iperf-arp-scan/DSM_7.0
When the drivers are installed and running, it should be relatively straightforward to get deCONZ up and running in a Docker container (I have run deCONZ like that for quite a while without any issues, but I have since moved to a dedicated Linux server, zigbee2mqtt and a Sonoff Zigbee dongle).
