Amina S Charger Zigbee connection works half
We are using the Amina S wall charger since a few weeks. But the Zigbee connection doesn’t work correctly. After resetting the charger, everything works fine for 1,5 days after that half of the information is frozen. See print screen. Is this a Zigbee connection probleem of a software problem in the charge side?
I am using the Amina S charger for over a year now, never noticed any hickups,
I did perform a firmware upgrade (because of an issue with switching 3phase / 1phase charging)
You can find the firmware here
Is your zigbee mesh strong enough outside?
Thanks I dus the firmware update, hopefully it solves the problem.
I think the Zigbee mesh is strong enough, because it is quite close tot Homey it self and because i constantly receive information from the charger. But from a certain point it is not compleet.
If you do not succeed you can try Amina support or the app creator
My experience is both are very responsive
Hope things has worked out.
