Hi, I bought this temperature sensor and thought it works directly on the phone. I realize that I probably need a Mija aqara hub. I ask for advice on what to buy so that the temperature sensors can be trained to operate. thank you
No hub needed. Install the Xiaomi App (zigbee) and add the device.
Hello, I’ve already done this, but the app can not find a thermometer, I can not pair it, advice
Can you be specific which device you bought? And if indeed it is on the supported list of this app?
If it works directly on the phone, you probably are referring to the Bluetooth temperature and humidity sensor; which is not supported by this app (not Zigbee based)
The phone is a huawei mate 20 - a new model, android 8.1.0
Hello, I have two app, xiaomi home and aqara home.
aqara home I’m looking for a temperature sensor icon, and it opens 4 icons with aqara hub, hub, air controller and wall qutlet, then there’s nothing to turn on then … I can not do anything with this app
-xiaomi - add device- temperature sensor- then write -not zigbee gateway found, cant add zigbee devices.
if I try automatic devices nearby, I turn on the thermometer blue indicator light and can not find it again
Please, which member does this work to describe the evaporation process. Thank you
Thanks for the help, but it does not go … show the app xiaomi / aqara zigbee, press install and show the app labeled - no devices availabile - in -install - but the install can not be pressed, it is colored gray
My best bet will be he has no Homey at all!
No Homey’s available.
I only have (Aqara Temperature and Humidity Sensor) and app honey on my phone
I already asked above if I need an additional device … for example Xiaomi Smart Home Kit Mijia Gateway Hub
Just ond step left And few hundreds Euros to spend.
RoyWissenburg thank you for your help, but the seller has misled me on the purchase …
Hello, thanks again for help, I could not answer before.
as far as I’m looking, this version is cheaper … I am sorry to confirm if any user has it?
https://www.aliexpress.com/item/MIJIA-Gateway/32822392120.html?spm=2114.search0104.3.40.21511e5aK837Y7&ws_ab_test=searchweb0_0,searchweb201602_3_10065_10068_319_10059_10884_317_10887_10696_321_322_10084_453_10083_454_10103_10618_10304_10307_10820_10301_10821_537_536,searchweb201603_54,ppcSwitch_0&algo_expid=1b14d9d0-aca3-499a-ad60-cd51a8dd6ca1-4&algo_pvid= 1b14d9d0-aca3-499a-ad60-cd51a8dd6ca1 & transAbTest = ae803_4
Guys, I have just put together an application that scans for these devices flashed with ATC firmware.
The code is quite dirty, feel free to use or modify it. ![]()
Already submitted as an application to Homey.
Hi, I’m 100% noob at Homey.
I was able to flash my LYWSD03MMC with ATC firmware, but I wasn’t able to get the GitHub - Zsoltt-dom/MiTempHum-Homey app in my Homey.
When I download the zip-file from Github and unzip it with 7-zip I get alot of errors.
Any ideas what I’m doing wrong?
Best regards
Johan
Hi! Thanks for your developments ![]()
I installed your application on my Homey Pro 2023, I have two temperature sensors and it is impossible to detect them via the app in Homey… Can you help me?
