Adding logic value to flow is missing zone name
Why are the devices listed on the logic value selection not sorted and categorized by zone or at least show the zone name. Currently impossible to know which device is which when creating flows.
Do you not have your devices sorted in to different zones/folders, and given different names that are relevant to the zone they are within? Adding all your devices with the same/default name is a terrible idea, and would cause that problem.
That’s exactly what I’m saying, I have all my devices in different zones (rooms) and thus it is very annoying that I would need to append the name of the zone to the device name it self. That is just double, if I have it like that I would see my device list based on zones and then each device in that zone would have both the name + the zone name in there. Not sure why I would like to have the zone name repeated for all devices. All names become very long then.
Which also means that if I want to move a device between zones I would also have to rename it, makes no sense… Why not use the zone names as categories in the list I provided as a screenshot or add the zone name in a smaller gray tone after the device name by default in these lists.
I’m sorry, but I find it unconscionable to not give devices unique names. Just having the default model name for all your devices so they all end up the same name makes absolutely no rational sense to me.
Even when I have a single light fitting with multiple bulbs of the same type in it, I still give each a unique name, even if I intend on controlling them as a group… if one were to have a fault, at least with unique names I would be able to tell them apart and which needed attention.
Yes, I think that is very unnecessary to repeat the “Kitchen” part for every device in the kitchen zone.
This is an example, I would like to avoid adding the “vardagsrum” part to every device, gets very annoying when you have a couple of 100 devices added. Here I have done it for a few just to make it easier to find them when managing my flows, etc. which I would like to avoid.
