Adding Hue Dimmer Switch
has anyone successfully added a Philips Hue Dimmer switch to Homey using the Philips Hue ZigBee app from HibbiSoft AB?
I tried it at least 10 times but always fail with an error message :frowning:
Any ideas? Thank you.
Johannes
Ok, solved it myself… Take out the battery for a minute and try it again. Then it worked.
Hello. I have added the Hue Dimmer Switch to Homey. I have configured the buttons via a flow as I am not able to make my Dimmer Switch talk to my light bulb directly when the latter is connected to Homey. This is why I am going via flows.
However, I am not able to configure a flow to set the temperature upon pressing multiple times on the ON button (native behavior when the switch is talking directly to the lamp). Do you have a hint?
Sure, only one thing would work, and you should use Homey with the flows.
You would need to build a flow which reacts on the button presses, however I do not see an event for multiple presses. But maybe you could use long press instead. Homey gives you a lot of possibilities. :grinning:
