[Abandoned] deCONZ
Happened to me too, especially with groups and individual lights. Haven’t paired too much attention to it yet.
Restart the app two times solved it for me. Everything works fine yet.
Not working here after several restarts… And the update to 17.1 does not solve it.
All Osram plugs are displayed incorrectly for me.
Yes the Innrs too… They go on and off in the app without doing anything. I think something with the poll data is incorrect or something like that?
Since the update yesterday I got the same error on with my tint devices again.
Sorry to hear that. Unfortunately I am quiet busy these days so it will take me some time to analyze this case. If you cannot wait until then I suggest to go manually back to 1.16.2 (see this commit here)
Btw: the 1.17.1 update isn’t related at all to this issue
This happens to all of my Innr SP120 plugs too. Even though quite a few are disabled for turn off (because they are used to measure power) they appear to be switched off.
(on 17.1)
Looking at the history they show ‘turn off - turn on’ about* every 15 minutes
*edit: it’s not ‘about’ it is ‘exactly’
And the good news is the plug doesn’t actually switch off, it just displays in the Homey app as being switched off, even though the history shows ‘turned on’.
That makes me wonder if this new/updated piece of code is causing this unexpected behaviour?
startIntervalStateUpdate() {
		if (this.pollIntervall) {
			clearInterval(this.pollIntervall)
		let interval = Homey.ManagerSettings.get('pollingIntervall')
		if (!interval) {
			interval = 15
No, this is already there for a longer time. The only thing that has changed there is that you now can configure the polling by yourself in the settings. But even that was already there bevore 1.17.x.
I had a quick look at it and I have an idea what the problem might be, just give me some time
Can anybody who is affected of this please test https://homey.app/de-ch/app/de.dresden-elektronik.deconz/deCONZ/test/ and give me some feedback if it now works?
I get the feeling it works better, have to try some more but with a few groups turning on and off the individual lights turn on too and off as well … will try some more later today
I installed it too and will share findings later. Thanks for the quick reaction.
About the polling interval setting: where should I be able to set it? For the Innr Plugs I don’t see that option? I
Polling is not device specific, therefore you find it in the app settings under advanced. Recomended is 15 minutes
Seems to be running stable again :+1:t2::innocent:
Does anyone have RGBW remote control of Müller-Licht (Tint) in use? I am still in need of a proper RGBW controller for my attic. Is this one working nicely?
My intention is to control the Fibaro RGBW controller with it to;
  • setup a few scenes
  • being able to easily adjust color / temperature / brightness
  • (if possible) demonstrate a few of the available animations (fireplace / alarm lights / …)
Yes I am using this one. It works just fine except for the group button (see deConz community for details).
Everthing seems fine now :grinning: :+1:
I just installed DeConz in Docker on my NAS, and I am keen te get it up-and-running. When pairing deConz to my homey, I am getting the following error:
Connected Succesfully, but you won’t receive live updates as the websocket port seems wrong.
I am not quite sure what to do here. Standard port 443 is used, and docker forwards another port (32769) to 443. I’ve tried to use the other portnumber (32769), without succes.
Can somebody point me in the right direction towards a solution or a method for troubleshooting? Thanks!
Assuming you’re using marthoc/deconz, you can configure the Websocket and HTTP ports by setting environment variables in your Docker config. For instance, I’m using these:
DECONZ_WEB_PORT: 2080
DECONZ_WS_PORT: 2443
And also two port mappings:
2080:2080
2443:2443
