[APP][Pro] Insights Graphs
Insights Graphs for Homey
This app allows you to export any Homey Insights data into beautiful graphs.
Currently has support for:
  • :green_circle: Color picker for graphs in trigger card
  • :heavy_plus_sign: Select a time window (day, week, month, etcā€¦)
  • :rice_scene: Graphs image tag
  • :black_circle: Light, dark or transparante for auto light/dark mode graphs
  • :chart_with_upwards_trend: Graphs types: Line and bar
Exports can be easily scheduled by using a trigger card and Insights Graphs action card in a flow. You can schedule by day or week or with time window you need.
Download in the Homey App Store!
:gear: Install this app on your Homey and create a flow with the Insights Graphs action card
:speech_balloon: Supported languages:
  • :uk: English
  • :netherlands: Dutch
Flow and outcome example
:computer: Developers
Cool app!
I just have a question: How did you handle the forced interpolation done by Homey?
The images you have posted shows temperature with 1 value pr hour. Homey is automatically interpolating values for every 5 minutes when selecting ā€œ24 hoursā€, even if my temperature sensor is only posting a value every 20 minute :thinking:
Looks nice, out of curiosity what generates the graph and converts it to an image?
I have written a data normaliser class that takes care of this :innocent:
Chart.js is used and then the end result is converted to an image
Do you have the source code public somewhere I can have a look?
As Homey already screws the original data by interpolating to 1m/5m/1h/6h intervals, its interesting to see what you do on top of this to try to correct the data :sweat_smile:
Are you stripping all the similar values to remove the stair-case graph?
My day-job is timeseries data, thatā€™s why this is interesting :wink:
We do not have the source code public. Should we want to do this, the app must first be published.
What I do is not too cool haha.
I use a timestamp convert all Homeys data to that timestamp and make a new collection with the choosen timestamp. Them all data gets combined and I calculate the highest values. And return my own new smaller list.
:sparkles: Live 1.0.0
The app is out now! Graphs all your Home Insights data right now and send it out with your favorite messenger app!
Try the live version here:
Isnā€™t it more simple to just use all the available data points and let Chart.js do the ā€œhardā€ work of converting them into a nice graph? Then you can leave out the step of creating your own smaller list. That way the chart should be a bit more accurate, right?
You can configure Chart.js to show you a max amount of ticks on the xAxes using maxTicksLimit .
I did the same for the charts in my own dashboard:
It would be even cooler to be able to do all of this locally, without the need of image-chart.com. Have you thought about using something like this?
Thanks for the feedback bas Iā€™ll take a look!
I decided for chartjs with a site to make the app more lightweight but Iā€™ll run some tests. It would be better to run 100% locally.
I will also work in making a device for homey so you can see your graphs within the homey app.
I did some testing myself, and chartjs-to-image works pretty great.
Iā€™m making an update for implementation thanks for the feedback.
Awesome! Iā€™m curious how it will turn out.
This is what I came up with so far:
I am plating around Sith the app but i zee you use aan app to send the image over Whatsapp, what app is that? I am using Callmebot but it doesnā€™t have the option to send aan image.
Hi, that is a app in development in collaboration with @martijnpoppen :wink:
Good to hear/read. Any idea when it wil be released?
P.s. As I am Looking for it I am willing to help with testing
How do you import it to image-charts?
Not sure how to connect from flow to image charts :smiley:
What exactly do you mean? You choose any trigger card. Then the insights graphs advanced action card. Then a message action card and choose the graphs tag as image there.
Gotcha thanks :wink:
Very nice app :slight_smile:
