News and tips on Heatzy - Pilot your electric radiators
Is this one done ?
https://community.homey.app/t/homey-pro-community-app-requests/2713/242
Yes this is the one.
What kind of device would you like to be added :
heatzy : heatzy pilote
What kind of category signal would the app use :
wifi/ cloud service
Is there a (public) API / documentation or known other implementations (like Blogs/Github etc)
https://mega.nz/#!D7A1GCoQ!v38RfUsFcTEt1jlhq7lAsrkI_RJxsL-qct3wTfoGaIw
Are you willing to loan or donate a device to a developer?
donate
For everyone who liked this post!
Version 10.0.0 â Major release! Now supporting most Heatzy features (boost and vacation modes, on/off scheduling, comfort 1 and comfort 2 modes). If you have 3rd generation drivers, youâll need to recreate your device to access comfort 1 and comfort 2 modes. Coming soon: temperature support for GLOW models and additional flows.
Hi @maverick62, yes sorry for the inconvenience.
Can you please confirm that this test version Heatzy App for Homey | Homey fixes the issue?
It works with expérimental version. Heaters are back, i can change the mode too directly on the heater.
But it seems that my flows with homey heating scheduler are not working.
I need to be on my computer to check this because they are advance flows. I will check tomorrow.
Thanks for the update,
Regards
I donât know this app⊠maybe flows need to be recreated, but it should be once and for all.
I am experiencing a problem since yesterday. After the power went off and on, Heatzy Pilote isnât responding anymore via Homey. It does respond via his own Heatzy app, but when I want to change the modus via Homey, I get the âdevice offline!â notification, and because it works via itâs own app, it isnât online. I can see it in my Wi-Fi network as well.
Iâve already removed the device and reconnect in Homey, restart the homey, restart the Heatzy app etc. but nothing works.
Hopefully someone can help me in the right direction.
Thanks!
Hi Fabian, very strange, everything works fine on my side, and I didnât deploy any new release recently.
Can you please join the Homey Slack community so we can dig in together?
Kind regards
Hi Olivier,
Problem solved. It wasnât on the Homey-side.
I could connect with the Heatzy android app when I was at home in the same Wi-Fi network, but not when I was away. So I removed the device in the Heatzy android app, reconnect it, and added it again in Homey.
Now it works!
Thanks
Bonjour,
Pourquoi cette application nâest compatible quâavec le Homey Pro et pas le bridge ?
Hi @Alexis_V,
Homey Bridge only works with some âlocalâ protocols: Homey Bridge
In particular, Heatzy devices arenât directly connected to Homey but through an API, what is not supported by Homey Bridge but only by Homey Pro.
Also, to develop apps to be run on Homey Cloud, you need to belong to the company brand developing the official app, or be commissioned by it â what is not my case. Youâll find details here: Homey Cloud | Homey Apps SDK
Kind regards
Okay good to know!
Iâm still hesitating between home assistant and homey but 400⏠for their pro hub is a big pill to swallow ahahâŠ
It seems very interesting, but having to rely on heatzy servers (and internet connection) is making me hesitating going this way⊠do you plan trying to make a direct connection with the heatzy pilote pro (or other modules) ?
The app supports every device including Pro except Pilot âCoolâ.
Sorry, I donât understand your answer: I understood from your previous answers that pilot pro is supported, but goes through Heatzy web API.
Do you plan to add support for direct connection between pilot pro and homey (without passing through Heatzy servers, so it still works even if heatzy stop or if my internet connection is down) ?
No, my app supports only connections via the API â no direct connection at all (I read your question too fast, sorry).
