[APP][Pro] Connect Solar Goodwe Inverter to Homey
GoodWe Inverter for Homey Pro
Monitor and control your GoodWe solar system from Homey Pro: live solar production, battery, grid exchange and house consumption, Homey Energy integration, Flow cards and dashboard widgets.
  • App ID: com.msd.inverter.goodwe
  • Requires Homey firmware >= 12.3.0
  • Issues and requests: GitHub
Connection options
Cloud (SEMS+) Modbus (local)
Data source GoodWe SEMS+ portal Inverter in your LAN
Refresh Depends on the portal / check interval Seconds
Internet required Yes No
Control No (read-only) Yes, on ET hybrids and DT/NS/MS/XS
Driver Devices Notes
GoodWe Cloud (Any) Any inverter registered in SEMS+ Read-only. Login with your SEMS+ account, system ID and inverter ID.
GoodWe Modbus (ET) ET hybrid inverters Monitoring and control, 2 PV strings, battery
GoodWe Modbus (DT/NS/MS/XS) DT, NS, MS and XS grid-tied inverters Monitoring, switch on/off
GoodWe Modbus (XS-30) XS-30 Monitoring
GoodWe Modbus (Battery / Feed-In / Load) Helper devices Show values of an already paired ET inverter for the Homey Energy tab
Inverters on the local network are discovered automatically; manual IP entry is available as a fallback.
Features
  • Solar power per PV string, battery power / SOC / SOH, grid import/export, house load, daily, monthly and lifetime energy, inverter temperature and status
  • Cloud driver: three-phase grid voltage, inverter firmware, generation totals
  • DT/NS/MS/XS: voltage, current, frequency, Wi-Fi signal, operating hours and a general alarm
  • Battery, Feed-In and Load helper devices for the Homey Energy tab
  • Flow triggers and conditions for solar, battery, feed-in and load power
  • Flow actions on ET (Modbus): Set Work Mode (General, Off-Grid, Backup, Eco, Peak Shaving, Self-Use), Set on-grid battery discharge depth, Set and enable grid export limit, Synchronize inverter clock, Switch On / Off (grid connection)
  • Flow actions on DT/NS/MS/XS: Switch On / Off (start / stop inverter)
  • Widgets: GoodWe Overview, Energy Flow and Energy History (hour, day, month and year view of grid import, house consumption and solar production)
  • Energy Flow can display a third-party wallbox or car through the Flow actions Set wallbox power, Set car state, Set car battery level and Remove wallbox and car from Energy Flow
  • If the cloud returns only partial data, working readings are kept and a warning is shown instead of showing zeros
Setup tips
  1. Give the inverter a fixed IP address. Only one client should poll it at a time.
  2. For Modbus, check the port and Modbus unit ID in the device settings. If you see timeouts, increase the polling interval.
  3. Test with a free Modbus tool (e.g. Modbus Poll) before reporting a problem.
  4. Cloud driver: use the same e-mail and password as in the SEMS+ app. If the portal has a temporary outage, the app keeps the last valid values.
  5. Control cards (work mode, discharge depth, export limit) need the ET Modbus driver. Changing them writes to the inverter, so use them sparingly in Flows.
Support the project
The app is free and built and maintained solo in my spare time. If it saves you money or hassle, a small thank-you via PayPal or Revolut keeps it going.
Bug reports
Please include your inverter model, driver, connection type, app version and the app log, either here or on GitHub.
I suggest use Virtual Devices. This application will allow you to monitor individual parameters of the inverter on one screen.
Virtual Devices
https://homey.app/en-gb/app/com.arjankranenburg.virtual/Virtual-Devices/
Here is guide how to setup it:
https://community.homey.app/t/howto-set-a-value-to-a-virtual-device/45883
This is what the result might look like:
@Jaromir_Matejko @Michal_Stranik
If you could please keep the conversation in English as much as possible, then more people will be able to participate and help you.
Hello!
I am trying to my Goodwe inverter but get an error:
measure_battery OutOfRangeError: 400 is greater than 100 (out_of_range)
What to do?
Hi, could you write me email to mistradev@gmail.com? If you will agree to share temporary your data, I will check why this is happening.
Hi! Thanks for the app! Really nice!
How often does it poll for new numbers?
Thanks.
@Lintin Default interval is 5 minutes, inverter also report only every 5 minutes, so it doesn´t make sense poll more often.
since this morning the app throws this error
{“'language”:“en”“function”:
['ADD"“UNBIND”|, hasError":true’msg"“T
““code”:“innerexception”“data”:”; comp onents”:
('para":“{'model":{'PowerStationld": 'xxxxxxxxxxxxxxxxx}”“langVer”:1 53 “timeSpan”:3131 6,'api":“http://eu.semsportal.com:82/api/v2/PowerStation/GetMonitorDetailByPowerstationld”
When I restart the app the error shortly disappears, but then (I assume after using api to get the data the first time) the error is shown again (red sign with ! Next to the goodwe device).
Anyone else experiencing this issue?
Suddenly the error disappeared. Seems to have been a problem on sems/goodwe site!
@Michal_Stranik Is this problem fixed? I got the same issue.
Around midday CEST the error didn’t appear again after I restarted the app.
As I didn’t recognize any app update, I think the issue has been on sems/goodwe site. In parallel i tried to install another solar app which also connects with goodwe. I wasn’t able to do so at that time. I just tried a moment ago and it works now.
Hi @Thorpedo @rikadoo , sorry, but I can´t fix something, what is not broken : )
It seems to be problem of Goodwe, their API is not reliable. I suggest contact their support.
When I contacted them some time ago, they wrote me, they can´t/won´t help me with API, so there is nothing I can do about these fails. App I made just use their API and if it fails …
Thanks for the reply, well then this app is useless for me :frowning: I will follow this app, maybe in the future when GoodWe fixed his API i will be usefull.
Thanks for the work!
It is interesting, that app works on my device without any problem. Did you try contact Goodwe support?
Hi michal,
Nice work! do you have the nice svg icon available for use?
Hi @Stortkoker , I don´t understand your question.Could you be so kind and clarify it for me?
You used some nice icons on your virtual devices, I hope you could share these.
-------- Oorspronkelijk bericht --------
I see, here is link for download:
Super! Many thanks
Hi @Michal_Stranik , have you looked into to send commands via this app to GoodWe? I have the battery solution and would love to be able to choose from triggers (electric prize) when the battery should start chargning/dischargning.
Thanks,
