[APP][Pro] ID Lock Next
Hi everyone,
I have published a test version of ID Lock Next a new community app for ID Lock smart locks on Homey Pro.
Install test version:
ID Lock Next is a ground-up, independent app for ID Lock smart door locks. It supports both Z-Wave and Zigbee through the same app, so the same settings, flows and user management should work no matter which module your lock uses.
Supported locks
  • ID Lock 101 - Z-Wave
  • ID Lock 150 - Z-Wave or Zigbee
  • ID Lock 202 - Z-Wave or Zigbee, using the same module/driver approach as ID Lock 150
Main features
  • Lock and unlock from Homey
  • Door open/closed, battery, tamper and heat alarm status
  • See who unlocked the door and how, for example PIN, RFID, manual, app or auto
  • User and PIN management from the app settings
  • Add, change and clear PIN codes
  • Master PIN support for Z-Wave
  • Import/export user list
  • Queue-based PIN synchronization with synced, pending and failed status per user
  • Notifications for lock events
  • Activity/audit log
  • Diagnostics page with health overview and downloadable report
  • Flow triggers for locked, unlocked and jammed events
  • Flow actions and conditions for away mode, auto-lock, service PIN, refresh and last user checks
  • Away mode support, including keypad sync using code + *
  • Advanced lock settings such as auto-lock, relock, sound volume and hinge direction
  • Z-Wave firmware update support through Homey
  • English, Norwegian and Swedish translations
Test status
This is currently a TEST release.
The main feature set is implemented. The ID Lock 150 Z-Wave and Zigbee modules have been developed against real hardware. ID Lock 101 and ID Lock 202 use the same command classes/module behavior, but I would especially appreciate feedback from users with those models.
Important note about Z-Wave firmware updates:
The app includes embedded official ID Lock Z-Wave firmware files for different lock models, but the OTA update feature has not yet been tested or verified by me. Using this feature is NOT ADVISED at this stage.
If you choose to try it anyway, you do so entirely at your own risk and responsibility. I take no responsibility whatsoever for failed updates, broken firmware, lock malfunction, loss of functionality, re-pairing issues, or any other problems caused by using the Z-Wave OTA firmware update feature.
Please report:
  • Pairing issues
  • Missing or wrong lock status
  • PIN/user sync problems
  • Flow cards that do not behave as expected
  • Translation mistakes
  • Anything else that looks unstable or unclear
Known roadmap item:
  • Codes added directly on the lock keypad are not yet fully reconciled back into the user list.
This is an independent community project. It is not affiliated with, endorsed by, or supported by ID Lock AS. Since this controls a door lock, please test carefully and use at your own risk.
Thanks for testing and for any feedback.
Still no tag for me. But might be unnecessary with the Condition card.
No insights (more than Battery), as indicated in change log.
Please describe what you mean about the tag.
Is it the flow card?
Is it a, When? And? Then?
What values does it need?
Also explain the use case.
Insight? I need more to go on… describe what you need.
It says in change log that there should be Insights for Away
I don’t see any need for it, but in case something intended is wrong.
There is not tag for Away. “Only” Battery and Last unlocked by. Not that I see any use case since the Condition card for Away is there now.
Good catch — the changelog wording oversold this. The Away history is recorded, but Homey only shows yes/no insights in the mobile app: open the lock device and tap the Away tile to see the on/off history (Homey keeps the last ~50 events). They never appear in my.homey.app’s Insights — the web app only charts numeric logs, so even the built-in “Locked” log isn’t shown there. That’s platform behavior, not something the app controls.
And as you noted, the “Away mode is on” condition card is the intended way to use it in Flows — boolean tags don’t show in text/number Logic fields either. I’ll phrase future changelogs as “history in the mobile app” to avoid the confusion.
Indeed, I am a moron… :rofl:
Im just wondering… If you have the door settings in app level settings and not in the device settings, how can you manage if the app have more than one lock?
How does the settings work in my house, garage and cabin?
You get a dropdown op top right for all your locks:
This is mockdata, so would be nice if someone could verify that it works correctly :smiling_face_with_sunglasses:
There are more specific lock settings in Advanced Settings in the device itself that are not available in the Settings pages.
But codes and tags need to be defined in the Settings pages or by flows that allow it with service codes.
Tnx, thats nice :clap: im gonna test it an reply
Fikk det til ĂĄ fungere pĂĄ garasjen :+1:
Bare ett tips du kan bruke i dine flowkort condition er ĂĄ bruke inverter sĂĄ slipper du sĂĄ mange like kort. Du finner det sdk3 dok Flow | Homey Apps SDK
Er det noen som har prøvd Z-Wave firmware update? Ser jeg har en update tilgjengelig (og 1.6.0).
Refactored some flow cards in 1.8.0
