I am developing a new app that connects to the Life360 app on your Android or iPhone device. This means you can add your family to the life 360 app and then the Family head can add the devices on your Homey. Using the device that is added, you can see the distance to homey, last seen, battery status places, etc. But also based on this there are a number of triggers (device comes home, leaves home etc).
I am wondering if there is an interest in such an app. If so I will continue to develop and publish it when finished. If not I will use it privately with the functions I need.
I have started testing the family for iPhone app (and it seems to work ok).
I certainly would like to contribute in testing this version. I looks a little more verstile and could potentially also replace my geofencing set up with IFTTT.
I’m very interested in Life360 for Homey. Used it, and liked it a lot, on Home Assistant.
Was a bit that there was no support for Life360 on Homey when I made the switch from HA to Homey.
Thank you guys, I am waiting until the app is approved. This will hopefully be this week. If you want you can of course install it using the homey cli.
Speed seems to represent to correct speed now, but driving is still always “No”. But I can live with that :).
WiFi switches to yes as soon as WiFi is activated, whether I’m connected to a WiFi network of not. I guess it’s there only to know if location id WiFi based or pure GPS based.
On my Huawei P10 lite it won’t work verry well. I have the app connected to mij 360 account, so far so good. But the app don’t update automatic, sometime’s when i restart the app i get new values but when i do nothing there is nothing hapen.
I walked thru the street but the app don’t see that i’m moving en no values changing till i restarded the app.
@Dabon, and @Jan_Willem_Visser the syncing seems fine. When you delete a place this works fine. I have seen when you add it in the Life 360 app it will not visible in the interface until you one time click the alarm bel icon between the place Don’t know why!??! After one sync you can switch it off again. Still checking why this is?
