If your device isn’t supported, please reply here or send a DM so I can add support for it.
I’m looking for users with the following Duux products:
Duux Edge
Duux North
Duux Beam (Mini or 2)
If you have any of these devices, please send a configuration report. You can send a report this way:
First, add any other device in the list and log in to your account
When the screen “No new devices have been found” appears, go to the Settings (More->Settings->Duux Gen2)
In the settings, get the configuration and send it privately. You can use the “Send” feature to send the report privately or you can send a DM and share the configuration that way.
Note that this app only works with Duux Gen2 devices (the new “Duux” mobile app with the Google Home/Alexa support). If your Duux Gen2 device isn’t detected or is missing from the list, you can request support in this forum topic.
Can you also add the Edge 2000 gen2 electric heater, not the oil version?
It will be great if you also can integrate the ECO mode for this.
Not all remotes (like mine) have the button on the remote for the ECO mode.
Thanks in advance!
I just tried adding it. It appears in the Debug menu (“successfully loaded data from 1 device”) and all of its information displays correctly. However, when I attempt to add it to Homey Pro, it says “no new devices have been found.” Seems there might be bug.
I’ve sent the debug logs via the Homey app. Debug ID: 09e09520-0cb5-4365-9494-59b98b4fe7b5
