[APP][Pro] whatwatt - Connect. Control. Contribute
whatwatt - Connect. Control. Contribute.
Central topic for questions/discussing the whatwatt App. You can use this topic to ask questions and share your experiences with the devices from whatwatt.
This app is developed by @Doekse in cooperation with whatwatt AG. For support use the e-mail link on the Homey App Store page. Support Contact »
Hi everyone, @Doekse ,
I’ve been running the WhatWatt Homey app for about a week now. see Landis and Gyr Smart meter (model E450) and Homey dongle
The device is connected via M-Bus to the L+G E450 and delivers stable data in both the manufacturer’s app and on their website.
In Homey, however, I’m experiencing dropouts:
  • Case a) After an internet outage (router restart required).
  • Case b) Without any obvious reason. This has become more reproducible since I created virtual devices for Phase 1, 2, and 3 (W).
Each time, restarting the WhatWatt app in Homey fixes the issue — but of course this isn’t ideal.
I also have some detailed charts:
  1. Router restart
  2. Created two Virtual Devices (using Device Capabilities)
  3. Another router restart
  4. “Random” data dropout
Why the Virtual Device? I created the virtual devices for Phase 1, 2, and 3 in order to:
  • monitor the load on each phase separately,
  • and have the separated total daily consumption for each.
Has anyone else seen this behavior, or found a way to keep the app stable without having to restart it manually?
Maybe A script to check sensor last update?
Thanks!
Thanks for elaborating! I’ve experienced the issues you are describing as well. Unfortunately the whatwatt Go doesn’t provide any logging when the connection drops so the connection isn’t re-established by itself.
I’m currently running a test build with a fix that monitors the data coming in and reconnects when data drops. Keep you posted on that fix :grinning_face_with_smiling_eyes:
This morning, another dropout. The internet connection was stable. I’ll remove the two separate virtual devices and check stability.
I’ve just released update v0.2.3 with a new reconnection mechanism. Please give it a try and let me know if it resolves the issue.
I added the two additional virtual devices – stable so far. (1h uptime)
Still up and running. 48h
:vulcan_salute:
Awesome, thanks for testing!
I’ve just pushed an update (v0.2.4) that ensures the connection stays active even if the device’s IP changes. Running a device repair will now also refresh the IP.
I have already assigned a fixed IP. :smiley:
Congratulations on the official launch :sparkler:
Do you think the “Current tariff” value could be used to feed Homey dynamics pricing?
hi Doekse and tlink, great so see your setup is working. When trying to connect via the app it indicates that it can’t find any new devices, while the whatwatt app is working fine. What am I missing? thanks for your help! Peter
Hi Peter, your Homey Pro will automatically search for the whatwatt Go on your local network. So make sure both devices are connected to the same network and are able to find each other.
Many thanks Doekse! I think that is the issue indeed. I assumed it was on the same network but discovered i’m not. Thanks! Peter
