Hi
First I have to thank you for making this app. finally
I don’t know if you have received a reply to the post above.
Here are the error codes I get from one of mine thermostats
DEL 1
{"result":"OK","output":{"vars":[{"waspVarName":"cust_New_ControllerSW","waspVarValue":"0"},{"waspVarName":"cust_CX_SW_Distributed","waspVarValue":"0"},{"waspVarName":"cust_Start_SW_Update","waspVarValue":"0"},{"waspVarName":"cust_Update_Counter_TimeOut","waspVarValue":"0"},{"waspVarName":"cust_Update_SW_Retries","waspVarValue":"0"},{"waspVarName":"cust_SW_Update_Fail","waspVarValue":"0"},{"waspVarName":"cust_Mini_FW_Updated","waspVarValue":"0"},{"waspVarName":"cust_General_RH_Setpoint","waspVarValue":"75"},{"waspVarName":"cust_controller_1_lost","waspVarValue":"0"},{"waspVarName":"cust_SW_version_update","waspVarValue":"X265_117.hex"},{"waspVarName":"cust_Controller1_Name","waspVarValue":"Uponor sentral"},{"waspVarName":"cust_C1_T1_name","waspVarValue":"Bad Vaskerom"},{"waspVarName":"cust_C1_T2_name","waspVarValue":"Stue"},{"waspVarName":"cust_C1_T5_name","waspVarValue":"Soverom MBR"},{"waspVarName":"cust_C1_T6_name","waspVarValue":"Bad MBR"},{"waspVarName":"cust_C1_T7_name","waspVarValue":"Soverom Alina"},{"waspVarName":"cust_C1_T8_name","waspVarValue":"Soverom Fine"},{"waspVarName":"cust_C1_T9_name","waspVarValue":"TV-Stue"},{"waspVarName":"cust_C1_T10_name","waspVarValue":"Entre"},{"waspVarName":"cust_C1_T11_name","waspVarValue":"Soverom Leah"},{"waspVarName":"cust_wifi_device","waspVarValue":"Nett"},{"waspVarName":"cust_ip_device","waspVarValue":"192.168.147.185"},{"waspVarName":"cust_Enable_SW_Update","waspVarValue":"1"},{"waspVarName":"cust_Succesfull_SW_Instal","waspVarValue":"0"},{"waspVarName":"cust_Temporary_ECO_Activation","waspVarValue":"1"},{"waspVarName":"cust_myecoprofile_name_1","waspVarValue":"Test ECO profil Soverom MBR"},{"waspVarName":"cust_C1_T5_Custom_Eco_Profile","waspVarValue":"0"},{"waspVarName":"cust_Low_temperature_Limit","waspVarValue":"590"},{"waspVarName":"cust_Enable_Low_Temp_Alarm","waspVarValue":"1"},{"waspVarName":"cust_Low_temperature_Hyst","waspVarValue":"36"},{"waspVarName":"sys_valve_exercise","waspVarValue":"0"},{"waspVarName":"sys_pump_exercise","waspVarValue":"0"},{"waspVarName":"sys_supply_diagnostic","waspVarValue":"1"},{"waspVarName":"sys_autobalance","waspVarValue":"1"},{"waspVarName":"sys_pump_management","waspVarValue":"0"},{"waspVarName":"sys_rh_control_activation","waspVarValue":"0"},{"waspVarName":"sys_supply_water_activation","waspVarValue":"0"},{"waspVarName":"sys_cooling_available","waspVarValue":"0"},{"waspVarName":"sys_forced_eco_mode","waspVarValue":"0"},{"waspVarName":"sys_heat_cool_mode","waspVarValue":"0"},{"waspVarName":"sys_comm_module_exist","waspVarValue":"1"},{"waspVarName":"sys_time_limit_bypass","waspVarValue":"0"},{"waspVarName":"sys_heat_pump_dynamic_heatcurve","waspVarValue":"0"},{"waspVarName":"sys_heat_pump_response","waspVarValue":"0"},{"waspVarName":"sys_heat_pump_defrost","waspVarValue":"0"},{"waspVarName":"sys_heat_cool_master_switch","waspVarValue":"0"},{"waspVarName":"Sys_CeilingCooling_Type","waspVarValue":"0"},{"waspVarName":"sys_HC_supply_limit","waspVarValue":"644"},{"waspVarName":"sys_HC_supply_hyst","waspVarValue":"72"},{"waspVarName":"sys_first_stage_offset","waspVarValue":"36"},{"waspVarName":"sys_day","waspVarValue":"3"},{"waspVarName":"sys_Month","waspVarValue":"8"},{"waspVarName":"sys_year","waspVarValue":"24"},{"waspVarName":"sys_minutes","waspVarValue":"16"},{"waspVarName":"sys_hour","waspVarValue":"4"},{"waspVarName":"sys_days","waspVarValue":"1"},{"waspVarName":"sys_seconds","waspVarValue":"30"},{"waspVarName":"Sys_ext_outdoor_temp","waspVarValue":"32767"},{"waspVarName":"sys_heat_cool_offset","waspVarValue":"36"},{"waspVarName":"sys_eco_mode_offset","waspVarValue":"72"},{"waspVarName":"sys_indoor_temp_switch","waspVarValue":"788"},{"waspVarName":"sys_outdoor_temp_hyst","waspVarValue":"36"},{"waspVarName":"sys_outdoor_temp_switch","waspVarValue":"824"},{"waspVarName":"sys_indoor_temp_hyst","waspVarValue":"72"},{"waspVarName":"sys_indoor_temp_delay","waspVarValue":"24"},{"waspVarName":"sys_pun_protocol_version","waspVarValue":"0"},{"waspVarName":"sys_OTA_status","waspVarValue":"3"},{"waspVarName":"sys_controller_1_presence","waspVarValue":"1"},{"waspVarName":"sys_controller_2_presence","waspVarValue":"0"},{"waspVarName":"sys_controller_3_presence","waspVarValue":"0"},{"waspVarName":"sys_controller_4_presence","waspVarValue":"0"},{"waspVarName":"sys_controller_1_lost","waspVarValue":"0"},{"waspVarName":"sys_controller_2_lost","waspVarValue":"0"},{"waspVarName":"sys_controller_3_lost","waspVarValue":"0"},{"waspVarName":"sys_controller_4_lost","waspVarValue":"0"},{"waspVarName":"sys_average_relative_humidity","waspVarValue":"0"},{"waspVarName":"C1_channel_1_fancoil","waspVarValue":"0"},{"waspVarName":"C1_channel_2_fancoil","waspVarValue":"0"},{"waspVarName":"C1_channel_3_fancoil","waspVarValue":"0"},{"waspVarName":"C1_channel_4_fancoil","waspVarValue":"0"},{"waspVarName":"C1_channel_5_fancoil","waspVarValue":"0"},{"waspVarName":"C1_channel_6_fancoil","waspVarValue":"0"},{"waspVarName":"C1_channel_7_fancoil","waspVarValue":"0"},{"waspVarName":"C1_channel_8_fancoil","waspVarValue":"0"},{"waspVarName":"C1_channel_9_fancoil","waspVarValue":"0"},{"waspVarName":"C1_channel_10_fancoil","waspVarValue":"0"},{"waspVarName":"C1_channel_11_fancoil","waspVarValue":"0"},{"waspVarName":"C1_channel_12_fancoil","waspVarValue":"0"},{"waspVarName":"C1_out_relay_heat_cool_SwFunct","waspVarValue":"0"},{"waspVarName":"C1_general_purpose_input","waspVarValue":"3"},{"waspVarName":"C1_output_module_configuration","waspVarValue":"3"},{"waspVarName":"C1_controller_relays_config","waspVarValue":"3"},{"waspVarName":"C1_channel_1_ceiling_cooling","waspVarValue":"0"},{"waspVarName":"C1_channel_2_ceiling_cooling","waspVarValue":"0"},{"waspVarName":"C1_channel_3_ceiling_cooling","waspVarValue":"0"},{"waspVarName":"C1_channel_4_ceiling_cooling","waspVarValue":"0"},{"waspVarName":"C1_channel_5_ceiling_cooling","waspVarValue":"0"},{"waspVarName":"C1_channel_6_ceiling_cooling","waspVarValue":"0"},{"waspVarName":"C1_channel_7_ceiling_cooling","waspVarValue":"0"},{"waspVarName":"C1_channel_8_ceiling_cooling","waspVarValue":"0"},{"waspVarName":"C1_channel_9_ceiling_cooling","waspVarValue":"0"},{"waspVarName":"C1_channel_10_ceiling_cooling","waspVarValue":"0"},{"waspVarName":"C1_channel_11_ceiling_cooling","waspVarValue":"0"},{"waspVarName":"C1_channel_12_ceiling_cooling","waspVarValue":"0"},{"waspVarName":"C1_channel_1_ave_temp","waspVarValue":"1"},{"waspVarName":"C1_channel_2_ave_temp","waspVarValue":"1"},{"waspVarName":"C1_channel_3_ave_temp","waspVarValue":"1"},{"waspVarName":"C1_channel_4_ave_temp","waspVarValue":"1"},{"waspVarName":"C1_channel_5_ave_temp","waspVarValue":"1"},{"waspVarName":"C1_channel_6_ave_temp","waspVarValue":"1"},{"waspVarName":"C1_channel_7_ave_temp","waspVarValue":"1"},{"waspVarName":"C1_channel_8_ave_temp","waspVarValue":"1"},{"waspVarName":"C1_channel_9_ave_temp","waspVarValue":"1"},{"waspVarName":"C1_channel_10_ave_temp","waspVarValue":"1"},{"waspVarName":"C1_channel_11_ave_temp","waspVarValue":"1"},{"waspVarName":"C1_channel_12_ave_temp","waspVarValue":"1"},{"waspVarName":"C1_rh_dead_zone","waspVarValue":"5"},{"waspVarName":"C1_rh_worst","waspVarValue":"0"},{"waspVarName":"C1_sw_version","waspVarValue":"289"},{"waspVarName":"C1_thermostat_1_presence","waspVarValue":"1"},{"waspVarName":"C1_thermostat_2_presence","waspVarValue":"1"},{"waspVarName":"C1_thermostat_3_presence","waspVarValue":"0"},{"waspVarName":"C1_thermostat_4_presence","waspVarValue":"0"},{"waspVarName":"C1_thermostat_5_presence","waspVarValue":"1"},{"waspVarName":"C1_thermostat_6_presence","waspVarValue":"1"},{"waspVarName":"C1_thermostat_7_presence","waspVarValue":"1"},{"waspVarName":"C1_thermostat_8_presence","waspVarValue":"1"},{"waspVarName":"C1_thermostat_9_presence","waspVarValue":"1"},{"waspVarName":"C1_thermostat_10_presence","waspVarValue":"1"},{"waspVarName":"C1_thermostat_11_presence","waspVarValue":"1"},{"waspVarName":"C1_thermostat_12_presence","waspVarValue":"0"},{"waspVarName":"C1_output_module_presence","waspVarValue":"0"},{"waspVarName":"C1_outdoor_temp_sensor_presence","waspVarValue":"0"},{"waspVarName":"C1_heat_cool_presence","waspVarValue":"0"},{"waspVarName":"C1_eco_mode_presence","waspVarValue":"0"},{"waspVarName":"C1_stat_pump_relay","waspVarValue":"0"},{"waspVarName":"C1_stat_supply_temp_hi_alarm","waspVarValue":"0"},{"waspVarName":"C1_stat_supply_temp_low_alarm","waspVarValue":"0"},{"waspVarName":"C1_eco_mode_forced_pub_thermo","waspVarValue":"0"},{"waspVarName":"C1_stat_demand","waspVarValue":"0"},{"waspVarName":"C1_stat_general_system_alarm","waspVarValue":"0"},{"waspVarName":"C1_device_system_alarm_eco_loss","waspVarValue":"0"},{"waspVarName":"C1_stat_heat_cool_mode","waspVarValue":"0"},{"waspVarName":"C1_stat_heat_cool_slave_input","waspVarValue":"0"},{"waspVarName":"C1_thermostat_change_1","waspVarValue":"0"},{"waspVarName":"C1_thermostat_change_2","waspVarValue":"0"},{"waspVarName":"C1_thermostat_change_3","waspVarValue":"0"},{"waspVarName":"C1_thermostat_change_4","waspVarValue":"0"},{"waspVarName":"C1_thermostat_change_5","waspVarValue":"0"},{"waspVarName":"C1_thermostat_change_6","waspVarValue":"1"},{"waspVarName":"C1_thermostat_change_7","waspVarValue":"0"},{"waspVarName":"C1_thermostat_change_8","waspVarValue":"0"},{"waspVarName":"C1_thermostat_change_9","waspVarValue":"0"},{"waspVarName":"C1_thermostat_change_10","waspVarValue":"0"},{"waspVarName":"C1_thermostat_change_11","waspVarValue":"0"},{"waspVarName":"C1_thermostat_change_12","waspVarValue":"0"},{"waspVarName":"C1_average_room_temperature","waspVarValue":"727"},{"waspVarName":"C1_average_setpoint","waspVarValue":"32767"},{"waspVarName":"C1_outdoor_temperature","waspVarValue":"32767"},{"waspVarName":"C1_alarm_type","waspVarValue":"0"},{"waspVarName":"C1_supply_temperature","waspVarValue":"32767"},{"waspVarName":"C1_worst_room_temperature","waspVarValue":"32767"},{"waspVarName":"C1_worst_setpoint","waspVarValue":"32767"},{"waspVarName":"C1_stat_heat_pump_dyn_heat","waspVarValue":"0"},{"waspVarName":"C1_hardware_type","waspVarValue":"1"},{"waspVarName":"C1_memory_map","waspVarValue":"1"},{"waspVarName":"C1_out_module_relay1_cmd","waspVarValue":"0"},{"waspVarName":"C1_out_module_relay2_cmd","waspVarValue":"0"},{"waspVarName":"C1_stat_out_module_relay1","waspVarValue":"0"},{"waspVarName":"C1_stat_out_module_relay2","waspVarValue":"0"},{"waspVarName":"C1_stat_out_module_com_lost","waspVarValue":"0"},{"waspVarName":"C1_pending_sw_version","waspVarValue":"279"},{"waspVarName":"C1_bootloader_sw_version","waspVarValue":"1044"},{"waspVarName":"C1_T1_bypass_enable","waspVarValue":"0"},{"waspVarName":"C1_T2_bypass_enable","waspVarValue":"0"},{"waspVarName":"C1_T5_bypass_enable","waspVarValue":"0"},{"waspVarName":"C1_T6_bypass_enable","waspVarValue":"0"},{"waspVarName":"C1_T7_bypass_enable","waspVarValue":"0"},{"waspVarName":"C1_T8_bypass_enable","waspVarValue":"0"},{"waspVarName":"C1_T9_bypass_enable","waspVarValue":"0"},{"waspVarName":"C1_T10_bypass_enable","waspVarValue":"0"},{"waspVarName":"C1_T11_bypass_enable","waspVarValue":"0"},{"waspVarName":"C1_T1_manual_fan_on","waspVarValue":"0"},{"waspVarName":"C1_T2_manual_fan_on","waspVarValue":"0"},{"waspVarName":"C1_T5_manual_fan_on","waspVarValue":"0"},{"waspVarName":"C1_T6_manual_fan_on","waspVarValue":"0"},{"waspVarName":"C1_T7_manual_fan_on","waspVarValue":"0"},{"waspVarName":"C1_T8_manual_fan_on","waspVarValue":"0"},{"waspVarName":"C1_T9_manual_fan_on","waspVarValue":"0"},{"waspVarName":"C1_T10_manual_fan_on","waspVarValue":"0"},{"waspVarName":"C1_T11_manual_fan_on","waspVarValue":"0"},{"waspVarName":"C1_T1_mode_comfort_eco","waspVarValue":"0"},{"waspVarName":"C1_T2_mode_comfort_eco","waspVarValue":"0"},{"waspVarName":"C1_T5_mode_comfort_eco","waspVarValue":"0"},{"waspVarName":"C1_T6_mode_comfort_eco","waspVarValue":"0"},{"waspVarName":"C1_T7_mode_comfort_eco","waspVarValue":"0"},{"waspVarName":"C1_T8_mode_comfort_eco","waspVarValue":"0"},{"waspVarName":"C1_T9_mode_comfort_eco","waspVarValue":"0"},{"waspVarName":"C1_T10_mode_comfort_eco","waspVarValue":"0"},{"waspVarName":"C1_T11_mode_comfort_eco","waspVarValue":"0"},{"waspVarName":"C1_T1_dehumidifier_activation","waspVarValue":"0"},{"waspVarName":"C1_T2_dehumidifier_activation","waspVarValue":"0"},{"waspVarName":"C1_T5_dehumidifier_activation","waspVarValue":"0"},{"waspVarName":"C1_T6_dehumidifier_activation","waspVarValue":"0"},{"waspVarName":"C1_T7_dehumidifier_activation","waspVarValue":"0"},{"waspVarName":"C1_T8_dehumidifier_activation","waspVarValue":"0"},{"waspVarName":"C1_T9_dehumidifier_activation","waspVarValue":"0"},{"waspVarName":"C1_T10_dehumidifier_activation","waspVarValue":"0"},{"waspVarName":"C1_T11_dehumidifier_activation","waspVarValue":"0"},{"waspVarName":"C1_T1_rh_control","waspVarValue":"0"},{"waspVarName":"C1_T2_rh_control","waspVarValue":"0"},{"waspVarName":"C1_T5_rh_control","waspVarValue":"0"},{"waspVarName":"C1_T6_rh_control","waspVarValue":"0"},{"waspVarName":"C1_T7_rh_control","waspVarValue":"0"},{"waspVarName":"C1_T8_rh_control","waspVarValue":"0"},{"waspVarName":"C1_T9_rh_control","waspVarValue":"0"},{"waspVarName":"C1_T10_rh_control","waspVarValue":"0"},{"waspVarName":"C1_T11_rh_control","waspVarValue":"0"},{"waspVarName":"C1_T1_eco_profile_number","waspVarValue":"0"},{"waspVarName":"C1_T2_eco_profile_number","waspVarValue":"0"},{"waspVarName":"C1_T5_eco_profile_number","waspVarValue":"0"},{"waspVarName":"C1_T6_eco_profile_number","waspVarValue":"0"},{"waspVarName":"C1_T7_eco_profile_number","waspVarValue":"0"},{"waspVarName":"C1_T8_eco_profile_number","waspVarValue":"0"},{"waspVarName":"C1_T9_eco_profile_number","waspVarValue":"0"},{"waspVarName":"C1_T10_eco_profile_number","waspVarValue":"0"},{"waspVarName":"C1_T11_eco_profile_number","waspVarValue":"0"},{"waspVarName":"C1_T1_pub_setpoint_override","waspVarValue":"0"},{"waspVarName":"C1_T2_pub_setpoint_override","waspVarValue":"0"},{"waspVarName":"C1_T5_pub_setpoint_override","waspVarValue":"0"},{"waspVarName":"C1_T6_pub_setpoint_override","waspVarValue":"0"},{"waspVarName":"C1_T7_pub_setpoint_override","waspVarValue":"0"},{"waspVarName":"C1_T8_pub_setpoint_override","waspVarValue":"0"},{"waspVarName":"C1_T9_pub_setpoint_override","waspVarValue":"0"},{"waspVarName":"C1_T10_pub_setpoint_override","waspVarValue":"0"},{"waspVarName":"C1_T11_pub_setpoint_override","waspVarValue":"0"},{"waspVarName":"C1_T1_cooling_allowed","waspVarValue":"1"},{"waspVarName":"C1_T2_cooling_allowed","waspVarValue":"1"},{"waspVarName":"C1_T5_cooling_allowed","waspVarValue":"1"},{"waspVarName":"C1_T6_cooling_allowed","waspVarValue":"1"},{"waspVarName":"C1_T7_cooling_allowed","waspVarValue":"1"},{"waspVarName":"C1_T8_cooling_allowed","waspVarValue":"1"},{"waspVarName":"C1_T9_cooling_allowed","waspVarValue":"1"},{"waspVarName":"C1_T10_cooling_allowed","waspVarValue":"1"},{"waspVarName":"C1_T11_cooling_allowed","waspVarValue":"1"},{"waspVarName":"C1_T1_rh_setpoint","waspVarValue":"75"},{"waspVarName":"C1_T2_rh_setpoint","waspVarValue":"75"},{"waspVarName":"C1_T5_rh_setpoint","waspVarValue":"75"},{"waspVarName":"C1_T6_rh_setpoint","waspVarValue":"75"},{"waspVarName":"C1_T7_rh_setpoint","waspVarValue":"75"},{"waspVarName":"C1_T8_rh_setpoint","waspVarValue":"75"},{"waspVarName":"C1_T9_rh_setpoint","waspVarValue":"75"},{"waspVarName":"C1_T10_rh_setpoint","waspVarValue":"75"},{"waspVarName":"C1_T11_rh_setpoint","waspVarValue":"75"},{"waspVarName":"C1_T1_comfort_heating_setpoint","waspVarValue":"0"},{"waspVarName":"C1_T2_comfort_heating_setpoint","waspVarValue":"0"},{"waspVarName":"C1_T5_comfort_heating_setpoint","waspVarValue":"0"},{"waspVarName":"C1_T6_comfort_heating_setpoint","waspVarValue":"0"},{"waspVarName":"C1_T7_comfort_heating_setpoint","waspVarValue":"0"},{"waspVarName":"C1_T8_comfort_heating_setpoint","waspVarValue":"0"},{"waspVarName":"C1_T9_comfort_heating_setpoint","waspVarValue":"0"},{"waspVarName":"C1_T10_comfort_heating_setpoint","waspVarValue":"0"},{"waspVarName":"C1_T11_comfort_heating_setpoint","waspVarValue":"0"},{"waspVarName":"C1_T1_minimum_setpoint","waspVarValue":"410"},{"waspVarName":"C1_T2_minimum_setpoint","waspVarValue":"410"},{"waspVarName":"C1_T5_minimum_setpoint","waspVarValue":"410"},{"waspVarName":"C1_T6_minimum_setpoint","waspVarValue":"410"},{"waspVarName":"C1_T7_minimum_setpoint","waspVarValue":"410"},{"waspVarName":"C1_T8_minimum_setpoint","waspVarValue":"410"},{"waspVarName":"C1_T9_minimum_setpoint","waspVarValue":"410"},{"waspVarName":"C1_T10_minimum_setpoint","waspVarValue":"410"},{"waspVarName":"C1_T11_minimum_setpoint","waspVarValue":"410"},{"waspVarName":"C1_T1_maximum_setpoint","waspVarValue":"950"},{"waspVarName":"C1_T2_maximum_setpoint","waspVarValue":"950"},{"waspVarName":"C1_T5_maximum_setpoint","waspVarValue":"950"},{"waspVarName":"C1_T6_maximum_setpoint","waspVarValue":"950"},{"waspVarName":"C1_T7_maximum_setpoint","waspVarValue":"950"},{"waspVarName":"C1_T8_maximum_setpoint","waspVarValue":"950"},{"waspVarName":"C1_T9_maximum_setpoint","waspVarValue":"950"},{"waspVarName":"C1_T10_maximum_setpoint","waspVarValue":"950"},{"waspVarName":"C1_T11_maximum_setpoint","waspVarValue":"950"},{"waspVarName":"C1_T1_minimum_floor_setpoint","waspVarValue":"680"},{"waspVarName":"C1_T2_minimum_floor_setpoint","waspVarValue":"680"},{"waspVarName":"C1_T5_minimum_floor_setpoint","waspVarValue":"680"},{"waspVarName":"C1_T6_minimum_floor_setpoint","waspVarValue":"680"},{"waspVarName":"C1_T7_minimum_floor_setpoint","waspVarValue":"680"},{"waspVarName":"C1_T8_minimum_floor_setpoint","waspVarValue":"680"},{"waspVarName":"C1_T9_minimum_floor_setpoint","waspVarValue":"680"},{"waspVarName":"C1_T10_minimum_floor_setpoint","waspVarValue":"680"},{"waspVarName":"C1_T11_minimum_floor_setpoint","waspVarValue":"680"},{"waspVarName":"C1_T1_maximum_floor_setpoint","waspVarValue":"788"},{"waspVarName":"C1_T2_maximum_floor_setpoint","waspVarValue":"788"},{"waspVarName":"C1_T5_maximum_floor_setpoint","waspVarValue":"788"},{"waspVarName":"C1_T6_maximum_floor_setpoint","waspVarValue":"788"},{"waspVarName":"C1_T7_maximum_floor_setpoint","waspVarValue":"788"},{"waspVarName":"C1_T8_maximum_floor_setpoint","waspVarValue":"788"},{"waspVarName":"C1_T9_maximum_floor_setpoint","waspVarValue":"788"},{"waspVarName":"C1_T10_maximum_floor_setpoint","waspVarValue":"788"},{"waspVarName":"C1_T11_maximum_floor_setpoint","waspVarValue":"788"},{"waspVarName":"C1_T1_setpoint","waspVarValue":"410"},{"waspVarName":"C1_T2_setpoint","waspVarValue":"410"},{"waspVarName":"C1_T5_setpoint","waspVarValue":"410"},{"waspVarName":"C1_T6_setpoint","waspVarValue":"725"},{"waspVarName":"C1_T7_setpoint","waspVarValue":"410"},{"waspVarName":"C1_T8_setpoint","waspVarValue":"410"},{"waspVarName":"C1_T9_setpoint","waspVarValue":"410"},{"waspVarName":"C1_T10_setpoint","waspVarValue":"410"},{"waspVarName":"C1_T11_setpoint","waspVarValue":"410"},{"waspVarName":"C1_T1_eco_offset","waspVarValue":"72"},{"waspVarName":"C1_T2_eco_offset","waspVarValue":"72"},{"waspVarName":"C1_T5_eco_offset","waspVarValue":"72"},{"waspVarName":"C1_T6_eco_offset","waspVarValue":"72"},{"waspVarName":"C1_T7_eco_offset","waspVarValue":"72"},{"waspVarName":"C1_T8_eco_offset","waspVarValue":"72"},{"waspVarName":"C1_T9_eco_offset","waspVarValue":"72"},{"waspVarName":"C1_T10_eco_offset","waspVarValue":"72"},{"waspVarName":"C1_T11_eco_offset","waspVarValue":"72"},
