With this SolPlanet app you can let your Homey Pro read the data from your SolPlanet inverter.
The app will read the data from the inverter every 30 seconds and store it in the Homey Pro. You can use the data to create flows and insights. The current power production, the daily production and the total production are available.
The required settings are:
- Local IP address of your inverter, example:
- 192.168.1.123
- OR https://192.168.1.123
Be sure to do the setup of the app while the inverter is online. The app can only connect with the inverter when the sun is shining ![]()
