Zyct-202
Just found out that the ZYCT-202 device is NOT in the list with supported devices. (the A…YCT-202 is).
Is this a missprint or correct?
Anyone tried to connect the Zigbee version (ZYCT-202) to the Homey. Will this work?
Rgdrs.
Then you should install the kaku zigbee app and not the kaku 433mhz app…
@RoyWissenburg you didn’t recognize it to be a Trust (KaKu) Zigbee device?
@KiJo-DuKa it is correct that it is not supported since this device (and similar Zigbee LightLink remotes) uses a Zigbee section that is not implemented (yet) in Homey’s SW (expected with Homey SW v2.1+)
