Zwave no_ack
Hi All,
Out of the blue all my Zwave devices stopped responding.
They do still work if a flow turns a light on or off, but they do not respond to my input via the Homey app.
In the app I get a ‘TRANSMIT_COMPLETE_NO_ACK’ error message.
See attached screenshots:
Bit of logging from the developer tool:
2024-10-07T08:59:57.753Z
Command[95] end: sendData
2024-10-07T09:17:32.294Z
Node[24]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[1]},"Sensor Type":"Temperature (version 1)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,217]},"Sensor Value":{"type":"Buffer","data":[0,217]}}
2024-10-07T10:13:23.124Z
Command[96] start: heal
2024-10-07T10:13:23.162Z
Command[96] status: heal, status: REQUEST_NEIGHBOR_UPDATE_STARTED
2024-10-07T10:13:28.386Z
Command[97] start: sendData
2024-10-07T10:13:35.238Z
[ProcessSendData]: To node: 14 with data: 0x2002 and txOptions: TRANSMIT_OPTION_ACK,TRANSMIT_OPTION_AUTO_ROUTE,TRANSMIT_OPTION_EXPLORE
2024-10-07T10:13:35.240Z
Command[96] end: heal
2024-10-07T10:13:41.554Z
[ProcessSendData]: Marked node 14 as noAckNode
2024-10-07T10:13:41.556Z
Command[97] end: sendData
2024-10-07T10:13:41.760Z
Command[98] start: isFailedNode
2024-10-07T10:13:41.766Z
Command[98] end: isFailedNode
2024-10-07T10:13:47.838Z
Command[99] start: sendData
2024-10-07T10:13:47.840Z
[ProcessSendData]: To node: 14 with data: 0x250100 and txOptions: TRANSMIT_OPTION_ACK,TRANSMIT_OPTION_AUTO_ROUTE,TRANSMIT_OPTION_EXPLORE
2024-10-07T10:13:54.110Z
2024-10-07T10:13:54.111Z
Command[99] end: sendData
Any suggestions what could have caused this to happen, and how I can fix this??
Same issue today, unknown route for a powered zwave device. Impossible to use from the app getting transmit_complete_no_ack and not able to heal.
As the option is not available like for Zigbee devices to repair. Anybody an idea of how to fix this? If I add the device manually again without removing it first, will it be replaced and all flows keep working out will it be recognized as a new device and have to fix all the flows?
During the pairing process of Z-Wave devices, they are automatically removed from the Z-Wave controller in the first step (first green check mark) and then added as a new device in the second step (second green check mark). Therefore you have to repair all flows afterwards.
Even though there is a script by @martijnpoppen that makes it much easier to repair advanced flows (link), I would like to ask you to contact Athom support first because of this issue.
I’ve been in contact with support about this, still without any luck.
Even after completely resetting the Z-Wave network and re-adding devices it is not working. Devices that are right next to Homey stoped working right after being added, giving me a unreachable error message.
