Zone Memory not saving Philips Hue bulbs color?
I have a flow that’s supposed to alternate between two Philips Hue scenes based on the time of day.
I have used Zone Memory to save the states of the zones I want. Zone Memory seems to save onoff, dim, light_hue, light_saturation, light_temperature, light_mode of the bulbs in the zone, but nothing about the color.
Is there anything I can do to fix this?
How do you think a color is generated?
These are the capabilities which are available, and from them, of course, the color is generated:
These values are stored with Zone Memory, already mentioned and explained by the developer of Zone Memory @Shakesbeard in this thread. Also mentioned, that there could be some problems with the Philips Hue app and Zone Memory.
Btw, I don’t understand why you want to use Zone Memory when it’s possible to set Philips Hue scenes via Athom’s Philips Hue app (I assume you use this app) afaik.
Hi! Thanks for the reply. Just a question regarding your sentence:
I assume you’re referencing the Activate the Scene card. I can’t figure out how it works. To me it seems to set the scene for the whole house, not the specific room I want to set the scene in. Is there a way to use this that I haven’t thought of?
Are you using a Hue hub? Tbh, it’s the best way to achieve what you want. Create the scene in the hue app and then use the activate hue scene action
Sorry for late reply. I haven’t used the Philips Hue Bridge in a while, but it was possible to activate the scenes created in the Philips Hue smartphone app with Homey. @Philip_Montgomery also confirms this. I guess it’s also possible for each single Hue bulb.
