Change Hue scene in room?
Zone Memory basically saves all data the device’s controlling app exposes. If the color is not saved then it might be an issue of the target app. I recently had someone observe an unexpected behavior with the Hue app and Zone Memory in regards to color or mode.
The problem is that the Hue app did not report the updated light data when expected. You can check if you have the same issue by checking what the color indicator of light shows in your Homey UI at the moment when you run the Store Device data stuff. Most likely even Homey will show the wrong color/mode. This needs a fix in the Hue app most likely. Or you delay saving the data to Zone Memory until the Hue app has refreshed its own info about the device.
