Zigbee temperature sensor with probe (wired)
I have been looking around but just cannot seem to find a temperature sensor like this one using zigbee (that is placed indoors but have a wire attached that can be used to read outdoor temperature)
NOTE: I am not interested in having a display or the need to measure both indoor and outdoor in the same device, it is mainly the external probe thing I need (a device put indoors with the zigbee communication and a wire with the probe attached that does the reading that is put outside)
or this (better picture of the wired probe)
At least here in Sweden this is the most used style of temperature sensor but all zigbee variants i can find is the type where you place the entire unit outside which is not great due to snow storms and extreme temperatures.
Anyone know if these types of devices can be found somewhere?
It seems like a trivial thing but apparently not :open_mouth:
Looking for the same thing, a temperature measuring device with an external probe that can be used in temperatures below - 20 Celcius… and of course being compatible with Homey Pro. It’s to be used in freezers with temperatures just below - 20. The ones I have used (without external probes) are useless since they just stop working and/or when placed inside the freezer lises too much signal.
I found the perfect product now 2025, uses Zigbee so no need for internet, seems to draw very little battery, very fast updates, works perfectly so far (had it for 1.5 months) and feels like a very well built product and pretty cheap as well!
Temperaturgivare, Zigbee, IP65, Sond, SNZB-02LD - StyraHem
Are you using Pro or Bridge?
The app it needs runs on any Homey model.
do you also know if there is a version with a humidity meter on a probe?
SONOFF SNZB-02LD is only a thermometer.
As far as I can see Sonoff doesn’t have external humidity sensor on any device.
thanks for the check
