Zigbee stuck in start up
Any Tx-Rx data are irrelevant, when-after you move it from existing Zigbee mesh, to any other mesh. Running two Zigbee mesh in the same household might have unexpected results, mostly if you will be running them on same channel or even having interference with Wifi but if you have this option, why not.
How do you know ?
But if you removed Zigbee routers (plugs), you might loose connectivity for some of the other devices unfortunately (battery operated ones).
Which bridge?
Yeah something new influenced Zigbee mesh for some of you, seems to be few isolated cases but would be great to understand the culprit. As I said, I have mutliple cheap Chinese Tuya, Aqara, IKEA etc. - 83 of them, running fortunately just fine.
So my tuya devices are over active and then not seen for hours and then over active again. They are non responsive when trying to use them. As a result my end devices have stopped.
I had removed all devices from my SmartThings into Homey but now ive got to move them back whilst its broken!
My bridge - home bridge
Yes im aware that moving some will cut off others, but how can i see routing. In zwave its clear but not in zigbee
That’s not possible, if I’m not mistaken, current Homey 2023/6 chip do not provide that data and anyway, it’s not supported/provided by Athom anyway.
That’s quite interesting, which devices ? Do you have their model ID / manufacturer ? I might be looking on mine, whether I have them as well or not.
So these were showing last seen a few hours ago. Then they changed to this after a new snapshot.
These are double sockets. Only one side of some of them are working
I am still unabke to add ANY zigbee devices into homey, any brand. It gets to the device is being added and the log shows it joins homey but then i get the failed to connect message
Some of my motion sensors are reporting motion permanently now. Time to reset i think
Hmm, not much traffic is going through… have you tried simply to do maintenance on those routers or simply just trying to Interview them ?
It depends..if it’s firmware issue on Athom side, the issue might appear again.
Btw maybe some additional insights on Tx-Rx, might be helping to some of you :
Metric Direction relative to Homey Meaning
TX Homey → Zigbee device Frames transmitted by the Homey Zigbee coordinator
RX Zigbee device → Homey Frames received by Homey from devices
Typical examples:
TX (Homey transmitting)
  • On/Off commands
  • Level control commands (dimmer)
  • Zigbee cluster reads (ReadAttributes)
  • Configuration writes (WriteAttributes)
  • Binding or reporting configuration
  • Network management traffic
RX (Homey receiving)
  • Attribute reports (temperature, power, etc.)
  • Motion or contact events
  • Battery reports
  • Device announcements
  • Responses to Homey requests
TX Errors (Zigbee)
TX errors represent transmissions attempted by Homey that failed at the Zigbee MAC/network layer.
Typical technical causes:
  1. No acknowledgement (ACK) received
  • Device unreachable
  • Weak signal / interference
  • Broken routing path
  1. Route failure
  • Coordinator cannot find a valid route to the device
  • Routing table expired
  1. Device asleep
  • Common with battery devices
  • Transmission happens outside wake window
  1. Network congestion
  • Collision on the 2.4 GHz channel
  • Wi-Fi overlap
  1. Frame retry exhaustion
  • Zigbee retries transmission multiple times
  • After retry limit → TX error recorded
Practical interpretation
Pattern Likely meaning
TX increasing normally Homey sending commands/queries
RX increasing normally Devices reporting data
TX errors increasing slowly Normal mesh retries
TX errors increasing rapidly Routing problem or unreachable device
Are you 100% sure about this? This would mean that Homey has started requesting way more often data from these Zigbee devices.
Source perhaps somewhat unreliable but Google Gemini told me that TX can also go from device to Homey. It just depends who initiated it. And it seems that Tuya Zigbee devices are rather chatty. Something that should be possible to limit if you have them attached to a Tuya Zigbee hub. Or if you create your own version of the Homey Tuya Zigbee app and add these settings. This is something that I have done for the bigger part:
No, it depends on which data sources’ interface you are looking:
If it’s the zigbee controller: Tx means Transmitted to device;
If the zigbee device has an interface for you to look on, then Tx means Transmitted to controller.
So, on the developer site, Tx = Transmitted to zigbee device
Rx = Received from zigbee device
Ah ok, so it is just the point of view.
Wel that would then mean that Homey is sending waaaaay more messages to Tuya Zigbee devices than to other devices. And it would mean that the change of settings I have applied is useless.
Edit: turns out that an acknowledgement is also a TX message
Wanted to get back to this issue. Things seem to be back to normal. My Zigbee devices are responsive again and after installing the last stable version I opted out of the experimental updates. So far, so good.
What I still notice is that at least the TX values (and I think the RX values too) for all of the Tuya Zigbee devices increase rapidly!
It doesn’t matter if polling is set to 5 minutes or an hour: every second or few seconds the TX/RX number increases.
Are more people still seeing this? My main concern here is that although it is not directly noticeable I think it may be clogging up the network or my 2.4Ghz band.
