Hi, does the zigbee reset break all pairings with connected devices or does it just remove them from the Homey? I have to hue motion sensor that i can’t remove, see this thread
And i wonder if the reset could work.
A reset will delete all ur devices and all flows with that devices will be broken!
Ok, and that also means that the pairing with the divice will be reset? Because that’s what i want. The devices won’t just be removed from the Homey?
Correct. But sometimes you have to also reset your device itself before being able to pair it again.
