Zigbee could not be started
Zigbee could not be started.
My Homey has been working fine. a week ago it lost all zigbee modules, I restored my homey and it worked.
In that case it no longer works and I get the message “Zigbee could not be started.”
I have tried everything, restore, update, different power supply, nothing works.
I hope someone can help
Don’t forget to try another usb cable as well!
Else:
Start in recovery, and perform the so called “full software download”.
This solved the zigbee issue for several users.
Homey starts and I can easily enter homey. Homey writes so that it cannot start zigbee.
I’ve tried restoring, it doesn’t help
Then contact Athom support.
I had the same problem …
This procedure from Athom Support made my day :slight_smile:
Good luck
Had the exact same problem ’ Zigbee could not be started’ and after the support mailed me the same solution Keith posted I just found this post LOL.
Baseline, reinstall the firmware exactly like described and it should work.
Awesome…
I just had the problem with “Zigbee could not be started”, and this solution fixed it!!
Thanks!
Same happened to me and this solution fixed it. Now I have a happy wife again. :grinning_face:
