Z-wave switches, Zen35 and the Zen30 by ZOOZ
Hello, I have an issue with a couple ZOOZ Z-wave switches, Zen35 and the Zen30.
The Zen35 is not a supported device in the ZOOZ app for Homey Pro. It comes in as an unsupported device. The communication to this device is horrible and times out all of the time. The Zen30 is in the same room, so I believe it has to do with the nonsupport. I can control the main switch from Homey, but I cannot control or see any of the (4) scenery buttons. Any suggestions would be helpful.
The Zen30 physically works normal for the on/off and dimmer paddle and the single press relay button. I’m using the bottom button as a scenery button, no load on it. However, there are several actions that it can do, single press, 2- time, 3-time, 4-time, 5-time and long press that do not work. I can create a flow and test each one in test mode through the flow screen, but I cannot physically get any of the button actions to work. The instructions show a bunch of parameters that can be changed but none of these parameters are visible in the settings.
Update on my Zen30 issue: Fixed :star_struck:
How:
I excluded my Zen30 from Homey pro, preformed a factory reset. I pulled the switch to confirm what firmware was installed, it was Firmware 4.20. The latest firmware on Zooz website is 4.30. There are several ways to update the firmware for ZooZ hardware. (you do you on how). I chose to use my Home Assistant OTA with my ZooZ Long range USB dongle, it was pretty easy to do. I then initiated the exclusion of the Zen30 via Home Assistant Z-wave app and confirmed the exclusion via Zen30 switch.
I pulled the Zen30 back into Homey Pro after the Firmware update to 4.30 and it worked, Fixed :star_struck:
Important things to understand about the Homey Pro - ZooZ App.
Zooz ZEN30 Add “WHEN flow card” definitions, regardless if you pull the flow card from the Dimmer or the Bottom Relay:
Scene Button 1 = Top Paddle
Scene Button 2 = Bottom Paddle
Scene Button 3 = Bottom Relay
Central Scene Mapping - AS PER ZOOZ
Dimmer Upper Paddle:
1 x tap: load on to last / custom brightness; Scene 1, attribute 00
2 x tap: on to full / max brightness; Scene 1, attribute 03
3 x tap: enter inclusion (pairing) mode; Scene 1, attribute 04
4 x tap: Scene 1, attribute 05
5 x tap: Scene 1, attribute 06
6 x tap: change LED indicator mode (see parameter 1)
press and hold: increase brightness level; Scene 1, attribute 02
release: Scene 1, attribute 01
Lower Paddle:
1 x tap: load off; Scene 2, attribute 00
2 x tap: Scene 2, attribute 03
3 x tap: enter exclusion (unpairing) mode; Scene 2, attribute 04
4 x tap: Scene 2, attribute 05
5 x tap: Scene 2, attribute 06
press and hold: decrease brightness level; Scene 2, attribute 02
release: Scene 2, attribute 01
tap-tap-tap-tap-and-hold: change physical / Z-Wave control mode (see parameter 19)
hold for 15 seconds: initiate factory reset (then release and hold the upper paddle to complete the reset)
Relay Button:
1 x tap: load on / off; Scene 3, attribute 00
2 x tap: Scene 3, attribute 03
3 x tap: enter inclusion (pairing) mode; Scene 3, attribute 04
4 x tap: Scene 3, attribute 05
5 x tap: Scene 3, attribute 06
6 x tap: change LED indicator mode (see parameter 2)
press and hold: increase brightness level; Scene 3, attribute 02
release: Scene 3, attribute 01
My Advanced flow for Zen30
  • Turn on/off patio porch light - Paddle
  • Turn on/off Backyard He shed / Office inside lights - relay
  • Turn off Backyard He shed / Office lights - off / turn on Shed porch lights - Govee Fire lighting - Scene Button 3
  • Turn on/off couch lamps
Happy Programing ALL.
Ps. Zen35 still waiting for App support /development
