since a couple of weeks I´m having severe issues with my z-wave sensors.
Actually running on HP 23, RC 10.00.122. I came from the HP19 and migrated via backup.
Just enabled experimental versions, because they fixed things for z-wave, but no change.
Using several brands, mainly Fibaro (starting with HC2 years ago), they are included in almost every kind of secure, depending on age or brand. No unknown nodes in the developper section. Z-wave log shows [2023-07-02T10:57:55.532Z] Node[1]: [COMMAND_CLASS_DEVICE_RESET_LOCALLY] {} most of the lines.
In the beginning, every thing seemed to work fine. Since a couple of weeks, I recognised some flows not working. When looking at the sensors, their last update shows from 2 days to 2 years ago. Some Fibaro motion sensors work, when I take out the battery and replace it, all my Sensative don´t recognise anything.
Fibaro motion sensors drawn their battery within 2 days. Tried to exclude and include a Fibaro motion sensor: it does the steps (3xtamper) itself, without I´m touching the sensor and then gives an error message (something went wrong, please try again).
Tried to deactivate App by App for the z wave devices, nothing changed.
As I have >50 devices and a lot of flows, I don´t want to restart with a bare system, especially as I don´t know if that will change anything. I wonder, wheather the trouble started with RC 110, but I´m not sure at all.
Really got no more ideas, what to do. It seems, as if my network is flooded, but can´t find the reason.
So please , if anyone has an idea: thank you for any hint!
Thilo
