Hi folks …
I"m in process of migrating back to Home Pro (2026 model) and only have a few devices that are giving me issues. Main problem is Yale YRD226 Z-Wave locks and getting them to come online
I’ve tried several different apps and only got one lock to connect. This was only after I literally put the Homey Pro right next to the lock .. something I never had to do with SmartThings or Home Assistant. Two of the other locks, no matter how close I am to the lock they time out with a TX error. Also the one lock that is showing up I cannot see any history if someone manually controls the door and also cannot add/update users or PIN codes. This seems like a big step backwards compared to other systems I’m used to running .. although I have to admit I’m really enjoying Homey with the other devices (Matter, Z-Wave mainly).
I’m hoping someone has gotten this lock working .. not really interested in replacing the locks. Appreciate it …
Paul
You might be able to use SmartThings and Google Home to bridge the lock to Homey. You can create a Virtual Device in Homey and then create automations in Google Home that switch the lock on SmartThings when the virtual device switches on/off. For most devices this works, however I’m not sure if Google puts any restrictions on automations for smart locks.
Thanks .. I read somewhere else that the Z-Wave version of this lock is not supported by the system (I think maybe the proper choice of words is “app”). I’ve ordered the WiFi modules to go into these locks to see if that provides enough work around but was really hoping to just continue using these locks as they were implemented in other systems. I’m getting rid of SmartThings as soon as I can migrate a bunch of other devices over (ST is the thread router for a bunch of my matter devices). I’ve recently shutdown home assistant as well .. all in on Homey now
Thank you .. I did try that app and ran into same issues. However I ordered the Wifi modules for these locks and now have it running through Homey without issues. Thanks
