I have the Yale Smartlock / Doorman (WGS2) with the Smart Living Yale Module 2 (Z-Wave).
Is there anyway to get it work with Homey without the Smart Living Hub from Yale?
According to mentioned thread below it is not possible, but it’s some time ago and I was wondering if others have had success?
I also have the Somfy Tahoma (for my IO-Connect devices) - but I can’t see any option to connect this way around.
Any Ideas - or shoud I really purchase the third control box! The idea with Homey is to avoid this
Unfortunately being members of the alliance doesn’t mean the devices WILL work together but rather could be made to work together. So Homey will need an app that knows how to interpret the information from that device and the commands required to control it.
Have you tried the:
Yes, I did try all 3.
Yale Lock, just hangs, never loads
Yale Doorman asks for credentials, so I assume it requires the SmartLiving Hub from Yale.
Yale Digital Locks asks me, on the lock, to enter marsterpin + going to the menu for adding remotes. But, I never get pass this point due to no communication. I might be doing it wrongly, but the Lock times out.
You might have to put your Homey very close to the lock to pair it as with most z-wave devices. I’m not sure if it’s a security thing or just a problem with Homey but I had to move my Homey to withing about 1 meter of my Conexis L1 locks to pair them.
So I ended up buying the Yale Smart Home Hub.
Lock is now fully managed by the Hub.
However trying the Yale Doorman App for Homey | Homey I get an error on Username/Pwd (I’m 99.999% sure it’s correct)…
But I must admit I don’t have Verisure - Could it be that it only works with Verisure and not Yale Smart Hub >> I need an different app.? But I can’t find any that seems to work with Yale Smart Home Hub
